Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: TRAIL FIX TIP: What to do with a Busted Brakeline
  1. #1
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    54,769
    You can do what you can to help keep your brakelines out of harms way but, rocks, logs and other obstacles will still have a way of reaching up and snagging them when you least expect. Unfortuantely, it doesn't take much to sever a line or to even tear one out and when that happens, you had better hope you're in a position where braking isn't required. The good news is, even if you don't have a spare brakeline in your recovery kit, you can still get your Jeep back up and running or, should I say, "braking" again and in just minutes. This Trail Fix Tip of the Day will show you how.
    What you will need
    • Vice Grips
    • Zip Ties or Bungie Cord
    • Brake Fluid
    What you will need to do
    1. Set your vice grips to a tight setting and pinch off the damaged or broken break line. It is important to get this as tight as possible to prevent any further leaking.
    2. Route and secure your brakeline and vice grips up and out of the way of moving suspension componets using zip ties, a bungie cord. If it works, you can even secure them to an actual suspension component like a sway bar arm as you can be seen in this photo below.
    3. Open up your hood, remove the cap on your master cylinder and top it off with brake fluid.
    This will help you to get off the trail but remember to drive a lot slower especially if the compromised brakeline was on the front axle. With one brake missing, your Jeep will experience a dangerous and severe pull to one side when trying to slow down or stop. If you have a JK, your traction control system will also go crazy on you until it finally shuts down. Once you are able to get your hands on new replacement brakeline, you can use this write-up to help you to install it:
    Jeep JK Wrangler Brake Line Installation Write-Up
    I hope this little trail fix tip has been helpful to you
  2. #2
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,652
    Good idea! What do you have as far as a cleanup kit for trail spills? Do you carry the blue shop rags, paper towels or the absorbent pads?
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  3. #3
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    54,769
    Quote Originally Posted by OverlanderJK View Post
    bdmckenna posted this up a while ago in regards to spill kits:
    http://www.oreillyauto.com/site/c/de...word=oil+spill
  4. #4
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,652
    Awesome, thanks!
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  5. #5
    Caught the Bug Yellojk's Avatar
    Join Date
    Jan 2012
    Location
    Menifee
    Posts
    54
    Awesome idea. I need to add vise grips to my tool box.
  6. #6
    Living the WAYALIFE JAGS's Avatar
    Join Date
    Aug 2012
    Location
    SoCal
    Posts
    11,204
    Some great tips you've been putting out of late. I think I need to invest in some more toner as I'm going to print these out and keep in my trail bag. Will say though.... your recovery "bag" must be one of those magical Felix bags of trix. In all seriousness, how do you keep all these things in your rig? You have a big tub, tool box(es), multiple tubs....
    Maybe in another post you can snap a pic of how you have all these items stowed away "safely" in the back?
  7. #7
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,652
    Quote Originally Posted by JAGS View Post
    A few weeks ago he posted that he was working on a write up for "what to bring on the trail" to include tools and all that. I'm sure this will be included in that.
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  8. #8
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    54,769
    Okay, here's a couple of shots of most of the stuff I carry with me. Mind you, these are just my tools and recovery gear and the first shot is with everything inside the back. The red bag up front is common tools and the black one is recovery gear. If I'm running a trail where I think they will actually get used or, if I'm on a camping trip, these would be right behind my seat instead.
    After pulling out the two bags up front, these are what's left. Welder on the left, 2 fluid boxes in the middle, welding helmet/gloves, electrical and small parts bag and then on the far right, an another tool bag containing things I don't use as much such as a vice, power tools, etc. Up front, you will see the a big pry bar and in the brown roll, I carry a smaller pry bar, big ass crescent wrench, torque wrench and ball peen hammer which normally get stowed behind the rear bench and in between the tuffy deck wall.
    Some of the smaller bags and welding helmet typically go under the rear seat to help free up room for things like camping gear.
  9. #9
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,652
    Guess I found a use for this now.
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  10. #10
    Join Date
    Aug 2012
    Location
    SoCal
    Posts
    11,204
    I recall seeing that too, but it was top of mind so thought I would ask.
    Okay, here's a couple of shots of most of the stuff I carry with me. Mind you, these are just my tools and recovery gear.
    Right, so this doesn't include the spare parts you also like to take that you've mentioned in conversation and also in some posts here. Looks like I need to beef up my trail kit a bit as I am missing a few essentials based on what I see. Nothing major (welder), just things like a crowbar, vice grips and zip ties. I think I have all these it's just a matter of storing them in the trail bag instead of the tool box in the garage.
    As overlander said, I'll keep an eye open for the "trail" write up, but feel better with your post here as at least I'll have most of the basics for the level of trails I'm currently running.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
