Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Opinions and Advice on Proposed Wheel / Lift Setup ?
  1. #11
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,692
    Quote Originally Posted by bladeolson View Post
    Ok, I think I made some choices... My Jeep is primarily for off-road adventures.
    EVO 4" Double DD
    EVO SPEC Shock
    ATX SLAB 17"
    37" Nitto Trail Graplers
    JK Front Axel Truss Dana 44
    Real Axel Kit 44 32 Spline
    FRONT AXEL SHAFT KIT
    FRONT spicer solid 1310 CV Driveshaft
    Yukon gear set for Dana 44 in a 4.88 ratio ( the guy at Northridge suggested this gear ratio )
    D44 Rubicon Front Master Overhall Kit with TIMKEN
    Personally, I'd skip the truss and just install c-gussets. A lot of times, installing the truss will cause your axle housing to bend and even if it doesn't if you're playing hard enough, it'll bend anyway. Not that it'll leave you high and dry though. If it were me, I would just save your money and upgrade to a ProRock 44 front axle if and when you might need it much later down the road. Of course, that's just me. Also, I would recommend a 1350 drive shaft. If you have a manual transmission, 4.88 will be a good ratio but if you have an automatic, 5.13's are what you want. If you're being recommended 4.88's with an auto, the guy you're talking to doesn't know what he's talking about.
  2. #12
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,599
    x2 on 5.13 with 37s.
    I'm running 4.88 on my 2010 auto and they were great with the 315s (35) but if i had known I'd be running 37s I would have gone 5.13s from the beginning.
  3. #13
    Caught the Bug bladeolson's Avatar
    Join Date
    Mar 2015
    Location
    Woodside, CA
    Posts
    92
    Thanks guys. This is all super helpful feedback. I am the first to admit I have a LOT to learn. I figure I should invest in the right gear as I am totally on board to make this an awesome rig. I do indeed have a manual transmission. So you guys think 4.88 is ok? or should I go 5.13? Also.... any suggestions on where I should buy this stuff would be helpful? I plan to buy myself and send to my shop for install. My mechanic is a total off-roader himself and WAY more mechanical than I am.
    how does the revised list look?
    EVO 4" Double DD
    EVO SPEC Shock
    ATX SLAB 17"
    JK Front Axel Truss Dana 44 ---> ProRock 44 front axle
    FRONT spicer solid 1310 CV Driveshaft ---> 1350 drive shaft
    EVO - C-gussets
  4. #14
    Been Around the Block WarriorJeep's Avatar
    Join Date
    Sep 2015
    Location
    Lakewood, CO
    Posts
    291
    Just a suggestion, buy your PR44 direct from Dynatrac. Seems going thru "vendors" doesn't always work out
    De Oppress Liber
    People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf.
  5. #15
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,692
    4.88 is okay and it'll get your Jeep feeling like stock again but if it were me, I would recommend 5.13 even with a manual as it will give you a bit more power. You will run a bit higher in the RPM's at highway speeds but really not enough to matter.
    With the exception of gears or anything that requires welding, you really could install pretty much everything yourself and save a ton of money. I have install write-ups for just about everything you're wanting to do and they should help a lot. But, I do understand how things can be for some and if you need a shop to do the work, I might recommend that you order your parts through them. You may find that they can get you a better deal on the total cost but, you definitely want to do your homework to verify as much.
  6. #16
    Join Date
    Mar 2015
    Location
    Woodside, CA
    Posts
    92
    Great info! That is super helpful. I think I ay go with the 5.13. Who would not want more power!!!???
    I would love to go through the process of installing myself to learn, unfortunately I don't have a nice set of tools and more importantly, my schedule does not give me too much time to work on this kind of stuff. I will certainly ask my mechanic if he thinks he can get a better deal for me. Their shop is pretty big so I assume they get nice pricing. I was sort of assuming shops would tack on additional margin on the parts. I'll see which will be a better deal.
    I am super excited about this upgrade, I've been thinking about it for a long time , can't wait. I'm guessing this will feel quite different coming up from Stock. I totally appreciate the help from you guys.
  7. #17
    Join Date
    Mar 2015
    Location
    Woodside, CA
    Posts
    92
    Quote Originally Posted by WarriorJeep View Post
    thanks, I was thinking the same thing for this part. I appreciate the input.
  8. #18
    Nothing but a Thing 2nd.gunman's Avatar
    Join Date
    Nov 2015
    Location
    Brisbane, Australia
    Posts
    2,413
    They all put a markup on parts they buy in to cover their time and delivery if required but they also generally get a pretty good trade discount. Unless the shop is trying to rip you off they should come in slightly less than retail pricing
  9. #19
    Join Date
    Mar 2015
    Location
    Woodside, CA
    Posts
    92
    One last question... Am I going to need smaller fenders with these 37"... I am not closed to changing them but I actually like my anvil color fenders.
  10. #20
    Token East Coast Guy MR.Ty's Avatar
    Join Date
    Apr 2014
    Location
    South East Georgia
    Posts
    6,489
    You could always cut your stock ones.
    2014 JKUR "Stumps"
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
