I'm gonna try to explain the theory behind the beads, I know it seems logical that with a high spot in the tread area that the beads would all congregate in and around that spot but it's just the opposite. When a heavy spot in the tire rotates up as the tire spins on a vertical axis , the tire bounces and the balancing media goes down. As this happens with a few revolutions, the media collects on the side of the tire opposite the heavy spot and counters the weight as the tire turns. The bead amount that it takes to counter the vibration will stay in that area due to centrifugal force and the other beads will distribute throu out the tire.
Here is a great video of how the beads react to an vertical imbalance, (these are used on big rigs but the theory is the same.
https://www.youtube.com/watch?v=ull...q-lmiKJBnIUaEL2LGnDejuxwPS7P9BRchdN1zPu3poC8w
Now the beads will not work if your tire has a
dynamic imbalance (left or right imbalance of the tire). The beads only compensate for a Static (up and down) imbalance of a tire.
The different manufactures also claim that you will get better milage out of your tires using these beads, I have no idea if this is true and I'm sure there's fine print in there as far as tire care.
