Although most of you are JK owners, I'm hoping you can help out with a steering issue on my WJ. It has a very similar steering design to a JK. Ever since I installed my Zone 4 inch lift, when I hit a bump with only one front wheel (either one), the steering wheel jerks a little. It's controllable, but I feel it could be better. Prior to the lift it didn't do this. If I go in a dip with both front wheels, no issues. I just put on new upper control arms and axle bushings with no change (they were worn out though). Everything in the front is either new or tight. The lift came with fixed lower arms that are longer than OEM. My caster sits at 4.5 with the new upper arms and bushings. My drag link and track bar are damn near perfect in parallel relation. Tires are new and balanced. Axle is centered under vehicle with with the adjustable track bar. Nothing has any play in it. Any thoughts?
