What are my choices for after market lockers for the front rubi 44
ARB RD157. You'll need 35 spline shafts also.
Yeah man, as many failures as you read about the e-locker, and the price is comparable, the ARB was a no brainer for me. You will love it.
Did you need the 35 spline shafts
Need is a very objective word. For me, all of the ARBs for the rear 44 were the same price so it made since to go with the 35 chromolys for a few hundred extra bucks and know I had a rear end that should be able to handle everything I throw at it where I wheel. I plan to do the same for the front. The only downside is spares aren't as prevalent as the stock spline counts so you are most likely going to be buying a new set if you want spares.
The ARB RD157 is only available in 35 spline.
Seems like I'm going to go with ox because I'm on a tight budget and not looking to spend the extra money for the 35 spline shafts
I fried my front locker and had it replaced with an Ox locker for that exact reason. I spent the money on a regear while they were at it and couldn't afford to tack on new shafts at the same time, plus the required compressor for the ARB.
If and when I replace the whole axle assembly, I'll probably do ARBs, but I've had absolutely no complaints with the Ox.
