Ddays
My apologies for the double post but I actually screwed up and meant for this to be stand alone and not in my build thread. There are probably quite a few guys out there that this may help
so I reposted.
Anyways, I was surfing online and stumbled across these mounts. They're made for RZR's and the clamps are 1.75". They fit the EVO tire carrier as they are the same dimension
(I ran out & measured before I ordered). Very well made. The ring clamp is welded on all sides to the mounting plate so it looks plenty strong. I tried mounting a can
in a couple different places and they all work well although some places blocked the rear lights. They are easy enough to mount that you could mount & unmount in a few
minutes if you want move around. They don't fit the rollbars though - those are larger diameter tube. They're not cheap at $37.50 each, but they are a great option.
			so I reposted.
