Page 16 of 16 FirstFirst ... 6141516
Results 151 to 155 of 155
Thread: Jeep JK Wrangler 2.5" Budget Boost Installation Write-Up
  1. #151
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,800
    Due to the design of the JK steering system, there will be ZERO change to your toe after installing a lift. As mentioned, your toe may look out but it will not be.
  2. #152
    Old Timer Jackal01's Avatar
    Join Date
    Jun 2013
    Location
    Houston
    Posts
    2,855
    Thanks, Eddie. It's those damn optional illusions.
  3. #153
    Fresh Catch
    Join Date
    Dec 2016
    Location
    Medina, Oh
    Posts
    1
    Thanks to the wide open fender design that the Jeep JK Wrangler has, you can pretty much run a 33" tires bone stock and get up on a set of 35" tires with very little effort. Of course, the easiest and most cost effective way to get the extra clearance you need to run them is to install a 2.5" coil spacer lift. More commonly known as a budget boost, coil spacers are cylindrical blocks that are made of a polymer or sometimes steel and they are designed to sit on top of your factory coils to give you as much lift as they are tall. When installed with a set of shock adapters, you will effectively have a small lift that will not change the quality of your ride and do it all for about $350. This write-up will give you a general idea just how easy it is to install a budget boost on your Jeep JK Wrangler.
    thank you, this is very helpful
  4. #154
    Fresh Catch monacept's Avatar
    Join Date
    Mar 2017
    Location
    FLORIDA
    Posts
    7
    This write-up was very helpful. I used it to install my BB over the weekend! IMG_1451.jpg
  5. #155
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,800
    Quote Originally Posted by monacept View Post
    Glad to hear it
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
