Page 170 of 258 FirstFirst ... 70120160168169170171172180220 ... LastLast
Results 1,691 to 1,700 of 2572
Thread: My life with a Brick
  1. #1691
    Old Timer Arrcherr's Avatar
    Aug 2017
    Palos Hills
    3,080
    Quote Originally Posted by JKbrick View Post
    I know I’m retarded electrically but if my dash is dead and turn signals don’t work will that all start working possibly if I pull the correct fuse? Maybe my clue is the headlights stuck on?
    If an electrical short is causing the issues and you eliminate the short by pulling a fuse then yes the other symptoms may disappear. It's not a full proof way to diagnose the issue but it's easy enough to do and could save a bunch of time.
  2. #1692
    Addict BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    6,434
    I may be wrong, but I think all that shit is driven by the CANBUS so if there is a wire or component that is grounded or loose, it would cause gremlins like you're experiencing. Not sure if pulling fuses would help track it, but it might.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  3. #1693
    Addict JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    9,653
    Quote Originally Posted by BaddestCross View Post
    Is the can bus at all related to the clock spring they replaced on the recall?
  4. #1694
    Aug 2016
    Palmdale, CA
    6,434
    Yes. The clockspring relays information back to the computer via CANBUS.
  5. #1695
    Addict jeeeep's Avatar
    Oct 2011
    Tx
    5,968
    headlights won't turn off? the headlight switch is a multi-switch and all run thru the clock spring. very possible the clock spring is bad again or the headlight multi-switch is bad
    wondering if the dash is grounded properly, take some wire, find a good spot on the dash to ground to and run it direct to the battery negative.
    I didn't read back far enough but are there any codes?
  6. #1696
    Feb 2013
    Leo, Indiana
    9,653
    Quote Originally Posted by jeeeep View Post
    Correct headlights on as soon as you turn the key, no dome light, dash is dead. There are no codes when it works but now it has quit working all the time. Before I could unhook the battery and it would work for 4 starts then quit working.
  7. #1697
    Feb 2013
    Leo, Indiana
    9,653
    I hope the clock spring is bad again, at least that should be under warranty
  8. #1698
    Old Timer Jsouder53's Avatar
    Aug 2017
    Gallatin Gateway, Montana
    4,923
    I hopes so for your sake, when will you be taking it in?
  9. #1699
    Feb 2013
    Leo, Indiana
    9,653
    Quote Originally Posted by Jsouder53 View Post
    I tried to call yesterday at 4 but got the Vm of the guy I wanted to talk to
  10. #1700
    Feb 2013
    Leo, Indiana
    9,653
    Gave my daughter the hard top for Franklin for the winter, adjusted my tailgate up, and got the spare put back on. Going to put the sway bar back on after dinner
