Page 35 of 37 FirstFirst ... 253334353637 LastLast
Results 341 to 350 of 370
Thread: Anyone have the LOD Destroyer Rear Bumper w/ Tire Carrier?
  1. #341
    Hooked aermid's Avatar
    Join Date
    Jul 2016
    Location
    Austin, TX
    Posts
    216
    I found a real sleek looking one that worked on the original hole position
    --Erin
    --Erin
  2. #342
    Fresh Catch
    Join Date
    Mar 2018
    Location
    Indiana
    Posts
    2
    EXCELLENT thread everyone!! I've been looking for a rear bumper/tire carrier for my JKU and the LoD fit all my requirements and more. I've just ordered it a couple of days ago, so I've likely got a bit of a wait, but I do have a question.
    I didn't order a bezel for the rear lights. Can I install them after the bumper is installed or will the bumper have to be removed to install the lights? I would rather do it one time if you know what I mean.
    Thanks!!
    Clay
  3. #343
    Join Date
    Feb 2016
    Location
    California, San Jose area
    Posts
    211
    I finished (finally!) my LOD Destroyer rear w/ linked gate yesterday. Went pretty smoothly for me, thanks to reading the directions carefully and reading this thread a few times.
    My learnings:
    • pay attention to the top / bottom bearing - despite my best efforts i got turned upside down, and pressed the top in the bottom spot, put in the grease seal, and then realized my screw up. I used the 1.5" socket i bought at the autoparts store (just $10) and another socket, with a drill bit to align, to tap the pair out gently with a section of 2x4 and a small dead blow hammer. Seems fine. but don't repeat my mistake!
    • for 35" tire, used the middle height and middle fore/aft bolt holes. some metal showing on either side of the tire, but fine for now. may move later. room to go lower even but will show more of the metal rack.
    • used blue / medium locktite on all tire carrier fasteners
    • zerk fitting - i scratched the black paint, touched up, but should have been more careful
    • other than that it seems good. will drive more and continue to listen for rattles if stuff moves / adjusts
    • i might shave the quick release flange where it is next to the tail gate... SUPER close to the gate, requiring care not to scratch upon engage / disengage. will likely dremel and clear coat it. *** Have others done anything on this???
    • i do have a lot of extra fasteners...
    Happy LOD customer here, with LOD all around.
  4. #344
    Join Date
    Feb 2016
    Location
    Posts
    211
    Quote Originally Posted by 89XJClay View Post
    Thanks!!
    Clay
    You'll need to remove the bumper, as best as i can see. not sure how you'd get your hands in there. unless you're more creative or smaller handed than me. It came with a flat plate / no light bezel, FYI.
  5. #345
    Fresh Catch dshipp2's Avatar
    Join Date
    Mar 2018
    Location
    Colorado
    Posts
    15
    Drilling the vertical holes
    Does anyone know why LoD didn't include an instructional on the drilling portion of the install? I feel like that part is the most brushed over, even in the video. I am trying to make sure I drill the vertical holes in the right spot. There are two circle indentations, but there is a curved metal just inside the indents. Is this where I am supposed to drill the vertical holes? and does drilling through those circle indents in the top automatically allign with the 2 holes on the bottom? drill points.jpg
  6. #346
    Old Timer Jsouder53's Avatar
    Join Date
    Aug 2017
    Location
    Gallatin Gateway, Montana
    Posts
    3,848
    Quote Originally Posted by dshipp2 View Post
    I would assume so... it’s been a while. I don’t remember having issues with figuring out the drilling instructions. Post some pictures and maybe I can help a little better.
    Welcome to Wayalife by the way! Stop by the give us a wave section! 👋
  7. #347
    Knows a Thing or Two Edwrds's Avatar
    Join Date
    Jul 2015
    Location
    SoCal
    Posts
    909
    The holes are already there. You just need to drill the ones on the side.
    2016 JKU
  8. #348
    Caught the Bug SSRuger's Avatar
    Join Date
    Mar 2017
    Location
    North Las Vegas
    Posts
    87
    Quote Originally Posted by Edwrds View Post
    I had to drill out the top 2 holes in my rear cross member.
    Sent from my SM-G955U using WAYALIFE mobile app
  9. #349
    Join Date
    Mar 2018
    Location
    Colorado
    Posts
    15
    Quote Originally Posted by Jsouder53 View Post
    The first two pictures are of the top vertical holes. The third picture, I was curious if you just use the threading that is already there? It's a picture of the forward holes on the side.
    Attached Images Attached Images
  10. #350
    Join Date
    Aug 2017
    Location
    Posts
    3,848
    I drilled the vertical holes.
    I didn’t have the threading on my frame rails, I used all the hardware from LOD. What bumper style are you replacing?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
