Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Pure Chaos!
  1. #1
    Fresh Catch
    Join Date
    Jan 2017
    Location
    West Virginia
    Posts
    10
    Pure Chaos!
    Base information: 2008 Rubicon Unlimited, 3.5" Rock Krawler, 37s, Trail Dash 2,
    So last week my gf and I are driving to dinner and I notice some lights start to come on. My traction control light, ESP BAS, ABS, BRAKE, HOT OIL, CEL, are all on within a matter of mins and my tach and speedo have begun to go back and forth between working and no signal. Temperature gauge is right around half where it normally is, and driving is normal. We park, go eat, come back out, starts up and drive it 30 mins home, nothing. Next morning I wake up drive it 10 mins away, do some errands, drive it back home. Couple hours later go out to leave, and all the lights are back on, and it won't even turn over. I mean where do I even start?
    Some more background on recent situations that may help you help me....
    Recently rebuilt the front axle, and got a proper alignment. (someone told me the steering wheel angle adjustment could be causing all of this, any truth?)
    Had a battery issue where it would just drain and go dead over night, but alternator was working properly. Carried a jump box with me for a week until it wouldn't even jump anymore
    had the battery tested (optima red top, less than 6 months old) was a bad battery and they replaced it. Haven't had any issues since.
    Any help or insight would be greatly appreciated!!
    -Tyler
  2. #2
    Nothing but a Thing
    Join Date
    Jul 2016
    Location
    Canada
    Posts
    1,296
    Quote Originally Posted by TMax173629 View Post
    -Tyler
    100% you have a loose negative terminal.
  3. #3
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    54,836
    Quote Originally Posted by JKDream View Post
    Agreed. Sounds like a loose battery terminal. If you've installed any accessories onto your terminals, remove them. The nut is tapered and will tighten up the clamp as you tighten the nut. A ring terminal in between the nut will prevent this from working and you will have problems.
  4. #4
    Addict Napalm's Avatar
    Join Date
    Jun 2012
    Location
    Flint, TX
    Posts
    5,654
    These guys are correct. Same thing happened to me on my 2014. Disconnected my winch cables from the battery and I never had the issue again.
  5. #5
    Fresh Catch
    Join Date
    Jan 2017
    Location
    West Virginia
    Posts
    10
    So a slight update that I have yet to resolve my issue and have not driven my jeep in almost a month now. I disconnected all accessories, I have changed both negative and positive terminals, we have swapped batteries, changed 2-3 grounds that showed some corrosion, and as of yesterday replaced the TIPM. My jeep continues to pulse all gauges, basically every light is on or off at any given time, and as soon as the red security light comes on, the jeep will not start. It flashes hot oil, with boxes around the gears that come on and off. I feel we have almost exhausted all options besides trying to take it to a dealer. Any opinions, ideas, whatever you got, please let me know.
  6. #6
    Old Timer JeepJeep75's Avatar
    Join Date
    Nov 2014
    Location
    Redondo Beach
    Posts
    2,725
    I saw this in another thread just recently about the sway bar motor shorting out from water. Apparently the sway bar motor fills with water, shorts out, and starts draining the battery. Try disconnecting the big square plug from the sway bar motor and see if things go back to normal.
  7. #7
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    3,645
    I had this problem before with the sway bar connector. It was causing for lights to go of on the dash. Not so dramatic, I would only get random single lights popping on my dash board, like lockers trying to engage on the freeway at 60 mph. Scary to see to say the least.
    Unplug you sway bar motor and check for corrosion on the connector, those motors are known for that.
    MY BUILT/REBUILD: http://wayalife.com/showthread.php?4...931#post859931
  8. #8
    Caught the Bug bekel's Avatar
    Join Date
    Sep 2015
    Location
    thompson falls mt
    Posts
    88
    I had something like that happen 1st time I took my jeep out dash lite up like a Christmas tree it turned out to be the abs control module went out put it in limp mode dash.jpg
    15 jku rubicon
    4" bds
    35 ko2
    9.5 cti
    altas bumpers
  9. #9
    Old Timer Andy5160's Avatar
    Join Date
    May 2016
    Location
    New York
    Posts
    4,392
    agreed wit WAYALIFE had the same issue about six month ago! Took the necessary steps and the issue was gone.
  10. #10
    Been Around the Block LetsGoMuddin's Avatar
    Join Date
    Apr 2013
    Location
    Massachusetts
    Posts
    341
    Have you checked for any active codes?
    1997 O|||||||O TJ
    Truck- Lite
    Metalcloak
    DynoMax
    33" Duratracs
    My Build: http://wayalife.com/showthread.php?2...-Jeep-TJ-Build
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
