QuicksilverJK
My PSC on my 3.8L acts up when it gets hot. The steering gets harder until you do one of 2 things either open the hood with it idling for a min to cool things down, or increase RPM. The way that I see it with the fluid at its hottest and thinnest the pump is having a hard time producing enough pressure. The question is if it's because of the heat or the pump. Should I try installing a cooler?
I have bled the system according to PSC instructions several times and even bled it with vacuum as well. And have only ever used their recommended fluid. Also this is the PSC pump that comes with their kit.
Thanks guys, any advice will be greatly appreciated.
