Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 103
Thread: Highway Overheating
  1. #21
    Nothing but a Thing
    Join Date
    Jul 2016
    Location
    Canada
    Posts
    1,296
    Quote Originally Posted by Lmoye22 View Post
    Once i installed the transmission cooler the hot oil light did go away under hard driving
    That was one of my issues as well. I originally had overheating from the mud, but it was actually the transmission overheating.
    On my 2013 the transmission cooler is built into the radiator, so it wasn't cooling properly.
    That's where your problem might lie, the transmission opposed to the engine.
    Mine still gets hot some days, but never enough to ding the oil light on, and that's perfectly normal.
    How long ago did you replace the transmission? If you've had the hot oil light since then, I'd replace the fluid.
    It's typically burnt after that light comes on.
    ** You might want to make sure they put enough fluid in the transmission as well.
    A lot of shops mess this up. Especially if it was a new transmission, they might have underfilled it.
  2. #22
    Join Date
    Apr 2016
    Location
    San Diego
    Posts
    217
    Hello. I run the Mishimoto radiator in my 2015 JKU with a Supercharger. I have not had any problems!!
  3. #23
    Fresh Catch hyvltge's Avatar
    Join Date
    Feb 2015
    Location
    United States
    Posts
    17
    Quote Originally Posted by Rocralr View Post
    What coolant do you use?
  4. #24
    Addict Ddays's Avatar
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    9,623
    Quote Originally Posted by hyvltge View Post
    Like WJCO replied in the other thread, there really isn't any reason to run anything other than what the factory recommends.
  5. #25
    Knows a Thing or Two danford.lau's Avatar
    Join Date
    Jan 2018
    Location
    West Los Angeles
    Posts
    834
    Bumping an old thread .. fully loaded Jeep going up long mountain roads in NorCal runs super hot . 235 to 240 going uphill . Can keep it under 235 with AC off and heat on still maintaining 60. Outside temps are 100+ . Trans temperatures seem to be okay at less than 170. Thoughts on what will help and what magnitude ...
    1) PS Bruiser bumper to lower the winch
    2) aftermarket radiator
    Others ?
    Coolant was recently flushed and coolant level is good .
  6. #26
    Old Timer HighwayTrout's Avatar
    Join Date
    Dec 2013
    Location
    California
    Posts
    3,547
    Quote Originally Posted by danford.lau View Post
    Others ?
    What gears are you running?
    Have you cleaned all the fine dusty silt and junk out of your radiator?
    en hopup veritas
  7. #27
    Join Date
    Jan 2018
    Location
    West Los Angeles
    Posts
    834
    Quote Originally Posted by HighwayTrout View Post
    4.88
    No I tried spraying water behind but need to remove the fan shroud to really access .
  8. #28
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    3,724
    In my experience overheating on the JK is most likely due to air flow blockage. Such as mud caked in the radiator fins and/or winch, lights, etc in front of the radiator. I would start there.
  9. #29
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,640
    Others ?
    Sounds about normal to me. Did you replace your thermostat and get your radiator pressure tested though?
    I just got back from another run up to the Sierras and the climb from the desert up the grade to the meadows get the temp gauge up to between the 3/4 and 1/2 marks with the Jeep loaded down running in 2nd gear. AC off, but no heat on.. 105° until we got up out of the dust bowl.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  10. #30
    Old Timer TrailHunter's Avatar
    Join Date
    Apr 2016
    Location
    SoCal
    Posts
    4,571
    Others ?
    I'm thinking the raised Winch isn't helping.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
