Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: What air pressure do you go to?
  1. #11
    Hooked Riverinechop's Avatar
    Sep 2017
    San Diego, CA
    142
    I have only aired down to 16-18. Quick question, non-beadlock wheels what is the lowest you would run?
  2. #12
    Hooked Clowe's Avatar
    Oct 2016
    Knoxville, TN
    198
    Quote Originally Posted by Riverinechop View Post
    I typically run 15-18 on stock rubi runs with 35's. I might be able to get away with a little less, but why risk it.
  3. #13
    Nothing but a Thing desertrunner's Avatar
    Mar 2013
    Great Falls, MT
    2,150
    Went to 12 in my old jeep on a Moab run with no beadlocks but only did it for 1 trail and got a little nervous about it so ran at 15 the rest of the trip, no issues
    12' 2dr Gecko Sport 6 speed
    PR44, ARBs, 4.88s, 35 spline rear, Adams 1350 Front & Rear, Rubi T-case, Rubi sway bar + Evo no limits, Evo armor & skids, 37/13.50" Cooper STT Pro, Evo 2" plush / OME med duty springs
    ***SOLD*** 08' JKU Rubicon 6-speed Stone White, 3.5" RK lift, 37" KM2s and lots more.
    ***CURRENT DD*** 16' F150
  4. #14
    Addict GraniteCrystal's Avatar
    Aug 2015
    Denver, CO
    6,130
    I usually drop to 12 when running a trail. Running 37s, no beadlocks.
  5. #15
    Knows a Thing or Two Samuelh3's Avatar
    Apr 2017
    Southern California
    804
    On my stock Rubis I aired down to 12 all the time with no issues. Again mainly rock crawling and not a lot of desert runs.
  6. #16
    Knows a Thing or Two Clearskies's Avatar
    May 2017
    Pine Mountain Club US
    984
    Quote Originally Posted by Samuelh3 View Post
    at this point I'm right about there also 12-14, next time I go crawling I'll try 10 probably
  7. #17
    Addict Brute's Avatar
    Nov 2015
    HI & WA
    7,967
    On my Brute with new 37 Toyo MT's on beadlocks, I run at 10 on trails, 6 for sand and 4 for snow...now that the tires are older, I add about two psi to everything...
    On the JK6, the Baja KR2's sidewalls are a bit stiff, so I run 8-10 for the rocks and 3 for snow...I haven't gotten into the dunes with it yet, but will this year
  8. #18
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    29,208
    Quote Originally Posted by farrier View Post
    ...the lowest to 15, no bead locks and c rated tires 15 psi is real squishy plus with the coopers they are sticky enough I've had no issues other than to much traction at times lol, short wheelbase joke there, the run we just did with Eddie and the gang we did at 20 lbs which kept our tires on the rims chasing Eddie when he sped up a bit in the hoopties
    I was just going to post something like this. I typically go down to 15, however with the stt pros (which I see that the OP has), I've found these things to perform just as well at 20 psi. The sidewalls are soft and these things just stick to the rocks. Ran a trail this summer and one of the guys pointed out that my tire was flat and it sure looked like it too. Checked it and it was at 15 psi.
    This picture doesn't show it well with the glare, but this was it.
  9. #19
    Hooked Sahara_Maverick's Avatar
    Sep 2016
    WA, USA
    241
    35 BFG KO on the 17in original 2007 aluminum rims here.
    On snow I go down to 10psi and works fine for me.
    On other trails with rocks, mud and other stuff I keep around 15psi.
    Sent from my SAMSUNG-SM-G891A using WAYALIFE mobile app
  10. #20
    May 2017
    984
    Cool
    So far, I love the STT Pro's, like you said, they just stick to rocks
Similar Threads
  1. Oil pressure
    By low profile in forum Jeep Cherokee & Grand Cherokee
    Last Post: 06-16-2017, 08:35 PM
  2. What pressure gauge do you use and why?
    By zimm in forum Jeep JK Wrangler
    Last Post: 04-17-2016, 12:59 AM
  3. Air Pressure With 40s
    By T&ERun in forum Wheels & Tires
    Last Post: 09-12-2015, 08:15 PM
  4. Oil pressure question
    By Cpyrd in forum Jeep JK Wrangler
    Last Post: 01-19-2014, 02:38 PM
