Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Psc Big bore
  1. #31
    Caught the Bug jcslax17's Avatar
    Oct 2012
    Phoenix AZ
    52
    Quote Originally Posted by DWiggles View Post
    The box comes with the ports already capped out of the packaging. Just leave them capped, install the steering box and hook up the feed/return lines from the steering pump. EaZZZZy.
    That’s what I thought but just wanted to clarify. Thanks. Can’t wait to feel the difference. I know my stock box isn’t long for this world after being abused
  2. #32
    Nothing but a Thing
    Jul 2016
    Canada
    1,296
    Quote Originally Posted by Mybadjk View Post
    So a question for ones with the big bore. What fluid do you guys use? Swepco? Has anyone used royal purple?
    This is dependent on what pump you are running, not the box.
    If it's the stock pump, you need to use ATF. If it's the PSC pump, either Swepco or Power Steering fluid but not ATF.
  3. #33
    Nothing but a Thing Mybadjk's Avatar
    Dec 2016
    Elko
    1,787
    I thought you could do this. Wasn’t sure, so I ordered the normal one.
  4. #34
    Dec 2016
    Elko
    1,787
    Quote Originally Posted by JKDream View Post
    Thanks thought it was dependent on the pump. Thought the atf has abrasives in it and wears out the o rings. Planning on using risky purple
  5. #35
    Nothing but a Thing QuicksilverJK's Avatar
    Apr 2016
    Reno NV
    1,405
    Last time I checked into this Royal purple used to be the standard for PSC. I guess they switched to Swepco because it has good anti foaming characteristics. I really don't think you could go wrong with either. Luckily for me I have a summit racing nearby that I can get Swepco at so that is what I run.
  6. #36
    Addict wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    6,722
    When talking with the Techs at PSC, they only recommend swepco and not ATF even in a stock pump. Make sure you run the flush first. There is something about ATF and the compressibility. Just what I was told by them, I’m not sure if the science behind it. But mine has been rock solid for almost a year now. We just put it thru it’s paces on Drummond and it preformed perfectly.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  7. #37
    Dec 2016
    Elko
    1,787
    Psc Big bore
    How much fluid did you guys use for the ones that ran just the box?
  8. #38
    Apr 2016
    San Diego
    217
    I just added my new PSC ran and XD box to my 2015 JKU. My setup is about the same as DWiggles post. So far I love it. I do not have any problems when I'm on the freeway. It's a win win for me.
  9. #39
    Been Around the Block
    May 2014
    san jose
    358
    Anyone running one with 40's without a ram in the rocks....Rubicon type trails?
  10. #40
    Caught the Bug StormTrooper_JK's Avatar
    Apr 2017
    Reno
    94
    I have the XDII box with upgraded lines on Rubi 44’s and 37s. I did not do their pump or the rest of their “overland kit”. Currently using regular ATF. Happy with the setup and no issues up to this point. It was stiffer to start but put it in last summer and it’s loosened up a bit. I would do it again for sure.
Similar Threads
  1. PSC Big Bore Pitman Arm Nut Size
    By Speedy_RCW in forum Jeep JK Wrangler
    Last Post: 10-01-2017, 05:22 PM
  2. Hydro Assist vs Big Bore XD Box
    By ZachJKUR in forum Jeep JK Wrangler
    Last Post: 05-26-2017, 03:41 AM
  3. big bore xd question
    By steep-n-deep in forum Jeep JK Wrangler
    Last Post: 04-07-2017, 05:08 PM
  4. AEV Pintler center bore
    By Jackal01 in forum Wheels & Tires
    Last Post: 03-28-2016, 08:42 PM
  5. Center bore
    By badassbrass in forum Jeep JK Wrangler
    Last Post: 05-22-2013, 06:48 PM
