Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Stabilitrak
  1. #1
    Fresh Catch Deankxf's Avatar
    Join Date
    Aug 2017
    Location
    Evans city, Pa
    Posts
    33
    Stabilitrak
    So I just got the jeep aligned today, everything’s right on, steering wheel is perfectly straight, but stabilitrak still keeps applying brakes to the front end on turns, anything else causing this?
  2. #2
    Fresh Catch kirame2's Avatar
    Join Date
    Jul 2017
    Location
    florida
    Posts
    38
    Mine does that too
  3. #3
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,647
    the stability control system sees one wheel spinning faster than the other and will apply the brakes assuming you are in some sort of slide.
    once you change from the OEM tire size it affects it.
    Make sure both tires are at the same tire pressure but better yet, disable the Stability control, you'll get a ESP warning at start up and a light on the dash but it'd better than having the system decide when it wants to apply the brakes.
    If you have a Rubicon you should have a ESP switch to temporarily disable it, it'll reset each time you shut down.
    Alternatively you can take it to the dealer to flash the ECU and disable it or do the steering wheel dance to permanently disable it.
  4. #4
    Nothing but a Thing 2nd.gunman's Avatar
    Join Date
    Nov 2015
    Location
    Brisbane, Australia
    Posts
    2,426
    What the fuck? Don’t disable it. It should still work fine with larger tires
  5. #5
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,741
    Larger tires should have no affect on the system. I'd check the connections and wires at each sensor to make sure they're tight and not frayed or damaged.
    If they're good, then one of the sensors is probably bad. Buy one and swap out one at a time until you find the culprit or replace all 4.
    There's probably a way to test the sensors with a meter, but I don't know what the readings are supposed to be.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  6. #6
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    3,645
    I am having to same issue. I recently replaced both my unit bearings up front, so both front sensors are new. I began looking into the rear couple weeks ago, I started by cleaning the tone rings
    Before
    After
    That didn’t fix it.
    I ordered new sensors for the rear ($20 each), so far changed the rear drivers side. Still doing it, I know I have slightly bent shaft on that side as well. With closer inspection of the sensor I can see that the tone ring is making contact with the sensor itself. I wonder if that’s the cause of the abs engaging.
    Here’s a shot of the sensor I took out on the side with a bent shaft
    I still need to replace the rear passenger side sensor to see if that will fix it. Hopefully someone with more experience will chime in on this issue.
  7. #7
    Join Date
    Dec 2017
    Location
    US
    Posts
    58
    Did you happen to disconnect the steering shaft or pitman arm? I'm wondering if the steering wheel is 360 degrees out of sync.
  8. #8
    Nothing but a Thing
    Join Date
    Jul 2016
    Location
    Canada
    Posts
    1,296
    Quote Originally Posted by RedRocker View Post
    That can't happen. The sector shaft only has three teeth and won't move out of sync.
    If you installed it wrong you'd know as you'd have no steering to one side.
  9. #9
    Join Date
    Dec 2017
    Location
    US
    Posts
    58
    Quote Originally Posted by JKDream View Post
    Right. The only way it would happen is if the steering shaft had been disconnected from the gear box and spun before being reattached.
    Sent from my Pixel 2 using WAYALIFE mobile app
  10. #10
    Nothing but a Thing
    Join Date
    Jul 2016
    Location
    Canada
    Posts
    1,296
    That would rip the clock spring wires out, and light up your dash.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
