Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 99
Thread: ROAM Offroad - JL Development - Front and Rear Bumpers, 4-Link Long Arm, & Side Armor
  1. #71
    Join Date
    Apr 2018
    Location
    Shreveport La
    Posts
    62
    Quote Originally Posted by Exodus Jeeps View Post
    Thereís a few available
    Who else makes one? I havenít seen any for the jl just curious thanks .
  2. #72
    Join Date
    Apr 2018
    Location
    Shreveport La
    Posts
    62
    Quote Originally Posted by ROAM View Post
    Thanks for the interest and support! We'll have more content, info, and pictures up on our site after we're back from EJS.
    I spoke with you via email so soon as you get the 8Ē kit I will be able to give some reviews. Unfortunately there isnít a lot of rock here in Louisiana so my rig will Be more geared for mud. I currently have a set of 42Ē Fury Mtís ordered right now. It will get abused , but in a different way than most people on here use there rigs. Seems like a great site happy to be a member and hope to learn a lot.
  3. #73
    Advertiser ROAM's Avatar
    Join Date
    Mar 2018
    Location
    Texas
    Posts
    22
    Arrow
    Quote Originally Posted by Ddays View Post
    Thanks for the thorough explanation. Looking forward to seeing the full production kit and the rest of your pieces.
    Quote Originally Posted by AllAmericanInfidel View Post
    Bumpers and sliders look great! Welcome to Wayalife!
    Quote Originally Posted by ScoobyCarolanNC View Post
    Looks great and the price is right!
    Thanks for the interest and support everyone!
    Your side steps say their rocker guards too? How does that work?
    In my opinion, while there are different ways that protection can be added to the actual rocker panels on the JL Body, before heading down that road we should first pose the question of: what are we protecting the rocker panels from? In my opinion, in this case protection should be added to resist rocks strikes (either kicked up by the tires or protruding from the ground) and/or car door strikes (from vehicles parked next to you). By adding side steps (any manufacturer), unless you're being impacted by a door that can clear the side steps (e.g. lifted truck or suv), you're covered already on the door strikes to your rocker panels.
    Rock strike and rock impact protection should be addressed by testing. In my opinion, there are two standards to beat for add-on rock impact production, the OE JL Rubicon rock rails (as the base standard) and then an underframe skid plate.
    The OE JL Rubicon rock rails are body mounted. While the OE JL Rubicon rock rails should bear the weight of the vehicle (forklift test), they're actually not meant to be load bearing because they're body mounted. The "rock rails" description actually refers to deflecting rocks that are kicked up as opposed to "rock sliders" which are more of an underframe skid plate.
    Our JL Side Armor Steps are constructed from mixed 7/32″ and 1/4" (high strength steel brackets) and mixed 1/8" and 5/32" high strength steel (topside outer surfaces) and are seam welded along the step plates. Any impact forces are dispersed and spread across all of the mounting points evenly as opposed to being concentrated in one area.
    The primary issue with adding any sort of underframe skid plate meant to protect the frame rails themselves is that you will lose ground clearance where the skid plate is attached. While there are solutions on other vehicles where they're advertised as allowing you to drag your vehicle over rocks and debris, if anyone actually attempts something like that the odds of getting high centered are pretty high. To clarify, in our opinion, avoiding the rocks will be safer than dragging/sliding your Jeep over them. On our JL Side Armor Steps, the mounting brackets sit higher than the lowest part of the OE body mount brackets.
    There are also the issues of maintenance, the ability to repair whatever its attached to, and then also if installation can be reversed (in the case that you've leased your JL as opposed to outright ownership). With most of the current rocker guards that attach to the rocker panels by means of either drilling a series of holes on the vehicle rocker panels or using adhesives, in my opinion, water ingress (at the holes drilled), water retention (in the gap between the rocker panel and the product attached to the rocker panels), how applied forces are absorbed/spread/dispersed (shear vs compression, e.g. on a sheet of metal attached to the rocker panel, how thick is the metal and if it dents is it just transferring the impact to the rocker in a localized area, dimple to dimple), and if a serious enough force was applied, can the underlying area be repaired.
    We've got both a body mounted version and a frame mounted version of our JL side steps: The ROAM JL Side Armor Steps which are body mounted and the ROAM JL Rock Sliders which are frame mounted. Our JL Side Armor Steps utilizes the same attachment points as the OE JL Rubicon rock rails. Our JL Rock Sliders utilizes preexisting bolt locations on the OE JL vehicle frame. Both our JL Side Armor Steps and our JL Rock Sliders do not require drilling or cutting or welding at all for installation and are designed to bear the weight of the vehicle (forklift test). Our JL Side Armor Steps are in production but we're still at least another few weeks out before our JL Rock Sliders will be committed to production. We're still testing our JL Rock Sliders to see if they're an improvement over our JL Side Armor Steps.
    Quote Originally Posted by The Great Grape Ape
    The ROAM slider are nice looking, and seem perfect as a step, but they likely wonít function the same for protection.
    Most people donít need or care for that level of protection and primarily need a functional step, that both looks the part and and has some of the added benefits not found on others (good platform with smaller gaps for dogs or high heels, good stone chip protection, etc), for most the ROAMs will be perfect
    However, that difference in price is also likely due to that difference in build priorities.
    What sets our design, build process, and quality apart isn't just how strong our JL Side Armor Steps are, but rather how they're designed and built. They're not just straight square tubes, but profiled and precision laser cut on the interior edge to evenly and consistently follow the curvature of the vehicle. While they're built to carry the weight of the vehicle (forklift test), in my opinion, the forklift test should not be the defining benchmark for strength because the OE JL Rubicon Rock Rails will also carry the weight of the vehicle during the forklift test. Our side steps feature heavy duty 7/32" high strength steel brackets and mixed 1/8" and 5/32" high strength steel superstructure construction (topside outer surfaces). I've attached an image below showing the inside profile of our JL Side Armor Steps.
    Quote Originally Posted by Allenn View Post
    We're still a few weeks out from releasing our 6" and 8" JL Long Arm suspension systems. We have a policy of testing everything on our own development and demo vehicles so what our customers receive will be perfect. We're still in the process of sorting through how much actual suspension travel we can get out of a set of coilovers that a 3rd party is currently co-developing with us. The design specifications call for: lets say if we were adding 4 inches of lift to a vehicle then we also need to add at least 4" of suspension travel so you're not losing negative suspension travel and articulation.
    Stay tuned for updates!
    Quote Originally Posted by onlyone View Post
    Welcome Roam! I dig the white letters. You can send me some of those slider/steps. Iíll give you a review.
    Thanks for support!
    When we're caught back up on production lets talk
    Attached Images Attached Images
    www.roamoffroad.com - JL Wrangler Custom Builds and Parts
  4. #74
    Old Timer NFRs2000NYC's Avatar
    Join Date
    Mar 2013
    Location
    NYC/NJ
    Posts
    2,612
    I am a huge fan of your rear bumper design. It gives you the benefits of the bumperless jeep clearance, but with a finished look and a great amount of function as well. I love the extra hitch options, but what's stopping me is the separate linkage mechanism. In your future renditions, I'd love to see a tail-gate linked carrier, as well as expansion options, like a top of the tire basket, or a way to mount 2 rotopax units. I also absolutely love the side rails, especially the lighted steps, but would really want to have them mount to the frame and be able to take a hit without buckling into the body. I do love the fact that they are tight to the body and hide the pinch seam. Would be cool to see you guys make a video showcasing how much of a beating they can take, so we can gauge if they would work for our application.
  5. #75
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    3,645
    Quote Originally Posted by 00jas00 View Post
    I recieved ROAM's products today to test out and give my opinion on. I must say they are very well thought out , and very ,very well built . I am in the process of the installation , test fit . And so far everything has been spot on . I'm attaching pics of the products so you can check them out
    So how do you like the bumpers? Itís been over 2 months now, any updates?
  6. #76
    Fresh Catch
    Join Date
    Aug 2018
    Location
    michigan
    Posts
    1
    Im really hoping their rear bumper becomes available soon, I really like the low profile design with hitches included!!
  7. #77
    Join Date
    Apr 2018
    Location
    Shreveport La
    Posts
    62
    I ordered a lift from them I hope it will be here real soon!
  8. #78
    Join Date
    Apr 2018
    Location
    Shreveport La
    Posts
    62
    Got my lift in should have it on end of next week.
  9. #79
    Fresh Catch
    Join Date
    Jul 2015
    Location
    Dayton, NV
    Posts
    6
    Very interested in ROAM products. Please keep us updated on your experience with the lift if possible. Thanks!
  10. #80
    Join Date
    Apr 2018
    Location
    Shreveport La
    Posts
    62
    Quote Originally Posted by Maxdady View Post
    Will do itís being installed this week.
Similar Threads
  1. Front or rear bumpers first?
    By buckweil in forum General Off-Road Tech
    Last Post: 02-21-2017, 04:32 PM
  2. EVO MFG Front and Rear Fender Armor
    By YukonBlu in forum Jeep JK Wrangler
    Last Post: 09-20-2016, 02:20 AM
  3. Front and rear bumpers
    By Torqt JK in forum FOR SALE (Active Members ONLY)
    Last Post: 12-24-2014, 03:20 AM
  4. Body armor front/rear bumpers (So.Cal.)
    By newtdog in forum FOR SALE (Active Members ONLY)
    Last Post: 04-19-2014, 06:33 PM
  5. Offroad evolution rear corner armor rock skins w/led taillights - brand new
    By highoctane in forum FOR SALE (Active Members ONLY)
    Last Post: 09-22-2012, 07:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
