Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: TORQUE SPECS : JL WRANGLER Reference Guide
  1. #31
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    56,298
    TRANSMISSION - MANUAL
    Description N·m Ft. Lbs. In. Lbs. Comments
    Drain plug 30 22 -
    Fill plug 30 22 -
    Shifter base to floor assembly bolts 8 - 70
    Control shaft cover assembly bolts 25 18 -
    Shift lever bolt 8 - 70
    Output speed sensor bolt 8 - 70
    Transmission stroke sensor bolts 25 18 -
    Input shaft retainer bolts 9 - 80
    Clutch release bearing retainer bolts 10 - 88
    Output shaft lock nut
    Shift fork detent bolts 25 18 -
    Shift fork support bolts 8 - 71
    Reverse idler gear shaft bolts 20 15 -
    Countershaft bolt 100 74 -
    Transmission case bolts 40 30 -
    Transmission oil separator bolts - - -
    Transmission shift guide plate bolts - - -
    Transmission mount bolts 47 35 -
    Shift cable retaining bracket 22 16 -
  2. #32
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    56,298
    Fuse Box Quick Reference Chart
    NOTE: The following information was setup using tables and you will NEED to use a computer or view it from the full site to see it formatted correctly.
    Location Description Size Type
    F01 Spare
    F02 Starter 40 Amp Green Cartridge
    F03 IBS 5 Amp Tan Micro
    F04 Fuel Pump MTR/FPCM 20 Amp Yellow Micro
    F05 Security Gateway 5 Amp Tan Micro
    F06 Spare
    F07 LTR Cool Pump — If Equipped 15 Amp Blue Micro
    F08 TCM-8HP CYGNUS 15 Amp Blue Micro
    F09 Spare
    F10 KIN/RF HUB/ESCL 15 Amp Blue Micro
    F11 UCI Port (USB & AUX) 10 Amp Red Micro
    F12 HIFI Ampliftier 25 Amp Clear Micro
    F13 Spare
    F14 Spare
    F15 IPC/SWITCH BANK-HD ELEC 15 Amp Blue Micro
    F16 Spare
    F17 Spare
    F18 AC CLUTCH 10 Amp Red Micro
    F19 Spare
    F20 CBC 1-INTERIOR LIGHTS 30 Amp Pink Cartridge
    F21 REAR WIPER 20 Amp Yellow Micro
    F22 ECM/PCM/MGU WAKE UP/PPU WAKE UP 10 Amp Red Micro
    F23 PCM/ECM 10 Amp Red Micro
    F24 Spare
    F25 MOD_SBW 10 Amp Red Micro
    F26 CBC 2-EXTERIOR LIGHTS #1 40 Amp Green Cartridge
    F27 Front Wipers 30 Amp Pink Cartridge
    F28 CBC 3-POWER LOCKS 40 Amp Green Cartridge
    F29 CBC 4-EXTERIOR LIGHTS #2 40 Amp Green Cartridge
    F30 Spare
    F31 DIAGNOSTIC PORT 10 Amp Red Micro
    F32 HVAC CTRL MOD/SCL/OCM/DPDM 10 Amp Red Micro
    F33 PTS/IRCM/AIRBAG DISABLE LMPS 10 Amp Red Micro
    F34 ESC/EHPS/SBCM WAKE UP 10 Amp Red Micro
    F35 BRAKE VAC PMP — If Equipped 30 Amp Pink Cartridge
    F36 TRLR TOW MOD — If Equipped 30 Amp Pink Cartridge
    F37 TRLR TOW CONN 7W — If Equipped 30 Amp Pink Cartridge
    F38 ECM 20 Amp Blue Cartridge
    F39 Spare
    F40 DTCM/AXLE LOCK FT_RR 15 Amp Blue Micro
    F41 IC/SGW WAKE UP 15 Amp Blue Micro
    F42 PCR CTRL FEED (ESS)/SPARE (BSG) — If Equipped 10 Amp Red Micro
    F43 PWR OUTLET (CARGO) BATT 20 Amp Yellow Micro
    F44 IRCAM HEATERS 10 Amp Red Micro
    F45 PWR OUTLET (CARGO) IGN* 20 Amp Yellow Micro
    F46 AUTO HDLP LVL MOD/LVL MTR/HDLP SW 10 Amp Red Micro
    F47 Spare
    F48 Spare
    F49 ORC 10 Amp Red Micro
    F50 HD ACC — If Equipped 10 Amp Red Micro
    F51 DSRC/USB/ISRVM/CSGM 10 Amp Red Micro
    F52 CIGAR LTR 20 Amp Yellow Micro
    F53 Spare
    F54 Spare
    F55 Spare
    F56 IN-CAR TEMP SENSOR 10 Amp Red Micro
    F57 Frt Drvr Htd Seat 20 Amp Yellow Micro
    F58 Frt Pass Htd Seat 20 Amp Yellow Micro
    F59 Spare
    F60 CSWM (HTD STR WHEEL) 15 Amp Blue Micro
    F61 LBSS/RBSS 10 Amp Red Micro
    F62 Spare
    F63 ORC 10 Amp Red Micro
    F64 Spare
    F65 Spare
    F66 HVAC BLOWER MTR FRT 40 Amp Green Cartridge
    F67 Spare
    F68 Spare
    F69 MGU (BSG) — If Equipped 5 Amp Tan Micro
    F70 INJ/IGN COIL (GAS)/GLO PLUG MOD (DSL) 25 Amp Clear Micro
    F71 Spare
    F72 HD ELEC ACC PKG — If Equipped 10 Amp Red Micro
    F73 PWR TOP LT 20 Amp Blue Cartridge
    F74 PWR TOP RT 20 Amp Blue Cartridge
    F75 PPU-BPCM & APM (BSG) — If Equipped 10 Amp Red Micro
    F76 ECM (GAS)/PCM (DSL) 20 Amp Yellow Micro
    F77 HTD MIRRORS 10 Amp Red Micro
    F78 COMP/INTRUSION/SIREN/INTRUSION SNSRS 10 Amp Red Micro
    F79 SMART BAR CTRL MOD 20 Amp Yellow Micro
    F80 PCM 15 Amp Blue Micro
    F81 REAR DEFROSTER (EBL) 30 Amp Pink Cartridge
    F82 FUEL HTR — If Equipped 30 Amp Pink Cartridge
    F83 GLOW PLUG — If Equipped 60 Amp Yellow Cartridge
    F84 UREA HTR CTRL UNIT — If Equipped 30 Amp Pink Cartridge
    F85 PM SENSOR — If Equipped 10 Amp Red Micro
    F86 BRAKE VAC PMP 2 — If Equipped 30 Amp Pink Cartridge
    F87 SUPPLY/PURGING PMP — If Equipped 10 Amp Red Micro
    F88 NOx SENSOR #1/ #2 — IF Equipped 20 Amp Blue Cartridge
    F89 SCCM/CRUISE CTL/DTV 10 Amp Red Micro
    F90 TRLR TOW PARK LMP — If Equipped 20 Amp Blue Cartridge
    F91 HORN 20 Amp Yellow Micro
    F92 HD ACCY #2 — If Equipped 40 Amp Green Cartridge
    F93 HD ACCY #1 — If Equipped 40 Amp Green Cartridge
    F94 TPM/CORAX 10 Amp Red Micro
    F95 Spare
    F96 PWR MIRROR SW 10 Amp Red Micro
    F97 RADIO/TBM 20 Amp Yellow Micro
    F98 SW BANK-HD ELEC/OFF ROAD 10 Amp Red Micro
    F99 Spare
    F100 ESC-ECU & VALVES 30 Amp Pink Cartridge
    F101 DTCM 30 Amp Pink Cartridge
    F102 DUAL USB PORT 15 Amp Blue Micro
    F103 HD ACCY #3 — If Equipped 15 Amp Blue Micro
    F104 PPU COOL PUMP — If Equipped 15 Amp Blue Micro
    F105 ICS/HVAC 10 Amp Red Micro
    F106 ESC-PUMP MTR 40 Amp Green Cartridge
    F107 TRLR TOW STOP/TURN LT — If Equipped 20 Amp Yellow Micro
    F108 HD ACCY #4 — If Equipped 15 Amp Blue Micro
    F109 TRLR TOW STOP/TURN RT — If Equipped 20 Amp Yellow Micro
    F110 POWER INVERTER 30 Amp Pink Cartridge
    F110 TRLR TOW BACKUP — If Equipped 20 Amp Blue Cartridge
  3. #33
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    56,298
    POWER DISTRIBUTION CENTER
    The fuses on a Jeep JL Wrangler are located under the hood and in a black box next to the battery. This box is known as the Power Distribution Center and the top cover has a diagram of all the cartridge fuses, mini fuses and relays contained within it.
    Because it can some times be hard to read, the following is a complete list of them according to what bank they're in, what they're used for and what type, size and color fuse is needed to replace them.
    LOCATION / DESCRIPTION / SIZE & TYPE
    F01 - Spare
    F02 - Starter
    40 Amp Green - Cartridge
    F03 - IBS
    5 Amp Tan - Micro
    F04 - Fuel Pump MTR/FPCM
    20 Amp Yellow - Micro
    F05 - Security Gateway
    5 Amp Tan - Micro
    F06 - Spare
    F07 - LTR Cool Pump — If Equipped
    15 Amp Blue - Micro
    F08 - TCM-8HP CYGNUS
    15 Amp Blue - Micro
    F09 - Spare
    F10 - KIN/RF HUB/ESCL
    15 Amp Blue - Micro
    F11 - UCI Port (USB & AUX)
    10 Amp Red - Micro
    F12 - HIFI Amplifier
    25 Amp Clear - Micro
    F13 - Spare
    F14 - Spare
    F15 - IPC/SWITCH BANK-HD ELEC
    15 Amp Blue - Micro
    F16 - Spare
    F17 - Spare
    F18 - AC CLUTCH
    10 Amp Red - Micro
    F19 - Spare
    F20 - CBC 1-INTERIOR LIGHTS
    30 Amp Pink - Cartridge
    F21 - REAR WIPER
    F22 - ECM/PCM/MGU WAKE UP/ PPU WAKE UP
    10 Amp Red - Micro
    F23 - PCM/ECM
    10 Amp Red - Micro
    F24 - Spare
    F25 - MOD_SBW
    10 Amp Red - Micro
    F26 - CBC 2-EXTERIOR LIGHTS #1
    F27 - Front Wipers
    F28 - CBC 3-POWER LOCKS
    F29 - CBC 4-EXTERIOR LIGHTS #2
    F30 - Spare
    F31 - DIAGNOSTIC PORT
    10 Amp Red - Micro
    F32 - HVAC CTRL MOD/SCL/OCM/DPDM
    10 Amp Red - Micro
    F33 - PTS/IRCM/AIRBAG DISABLE LMPS
    10 Amp Red 0 Micro
    F34 - ESC/EHPS/SBCM WAKE UP
    10 Amp Red - Micro
    F35 - BRAKE VAC PMP — If Equipped
    F36 - TRLR TOW MOD — If Equipped
    F37 - TRLR TOW CONN 7W — If Equipped
    F38 - ECM
    20 Amp Blue - Cartridge
    F39 - Spare
    F40 - DTCM/AXLE LOCK FT_RR
    15 Amp Blue - Micro
    F41 - IC/SGW WAKE UP
    15 Amp Blue - Micro
    F42 - PCR CTRL FEED (ESS)/SPARE (BSG) — If Equipped
    10 Amp Red - Micro
    F43 - PWR OUTLET (CARGO) BATT
    F44 - IRCAM HEATERS
    10 Amp Red - Micro
    F45 - PWR OUTLET (CARGO) IGN*
    F46 - AUTO HDLP LVL MOD/LVL MTR/HDLP SW
    10 Amp Red - Micro
    F47 - Spare
    F48 - Spare
    F49 - ORC
    10 Amp Red - Micro
    F50 - HD ACC — If Equipped
    10 Amp Red - Micro
    F51 - DSRC/USB/ISRVM/CSGM
    10 Amp Red - Micro
    F52 - CIGAR LTR
    F53 - Spare
    F54 - Spare
    F55 - Spare
    F56 - IN-CAR TEMP SENSOR
    10 Amp Red - Micro
    F57 - Frt Drvr Htd Seat
    F58 - Frt Pass Htd Seat
    F59 - Spare
    F60 - CSWM (HTD STR WHEEL)
    15 Amp Blue - Micro
    F61 - LBSS/RBSS
    10 Amp Red - Micro
    F62 - Spare
    F63 - ORC
    10 Amp Red - Micro
    F64 - Spare
    F65 - Spare
    F66 - HVAC BLOWER MTR FRT
    F67 - Spare
    F68 - Spare
    F69 - MGU (BSG) — If Equipped
    5 Amp Tan - Micro
    F70 - INJ/IGN COIL (GAS)/GLO PLUG MOD (DSL)
    F71 - Spare
    F72 - HD ELEC ACC PKG — If Equipped
    10 Amp Red - Micro
    F73 - PWR TOP LT
    F74 - PWR TOP RT
    F75 - PPU-BPCM & APM (BSG) — If Equipped
    10 Amp Red - Micro
    F76 - ECM (GAS)/PCM (DSL)
    F77 - HTD MIRRORS
    10 Amp Red - Micro
    F78 - COMP/INTRUSION/SIREN/INTRUSION SNSRS
    10 Amp Red - Micro
    F79 - SMART BAR CTRL MOD
    F80 - PCM
    15 Amp Blue - Micro
    F81 - REAR DEFROSTER (EBL)
    F82 - FUEL HTR — If Equipped
    F83 - GLOW PLUG — If Equipped
    60 Amp Yellow
    F84 - UREA HTR CTRL UNIT — If Equipped
    30 Amp Pink
    F85 - PM SENSOR — If Equipped
    10 Amp Red - Micro
    F86 - BRAKE VAC PMP 2 — If Equipped
    F87 - SUPPLY/PURGING PMP — If Equipped
    10 Amp Red
    F88 - NOx SENSOR #1/ #2 — IF Equipped
    F89 - SCCM/CRUISE CTL/DTV
    10 Amp Red - Micro
    F90 - TRLR TOW PARK LMP — If Equipped
    F91 - HORN
    F92 - HD ACCY #2 — If Equipped
    F93 - HD ACCY #1 — If Equipped
    F94 - TPM/CORAX
    10 Amp Red - Micro
    F95 - Spare
    F96 - PWR MIRROR SW
    10 Amp Red - Micro
    F97 - RADIO/TBM
    F98 - SW BANK-HD ELEC/OFF ROAD
    10 Amp Red - Micro
    F99 - Spare
    F100 - ESC-ECU & VALVES
    F101 - DTCM
    F102 - DUAL USB PORT
    15 Amp Blue - Micro
    F103 - HD ACCY #3 — If Equipped
    15 Amp Blue - Micro
    F104 - PPU COOL PUMP — If Equipped
    15 Amp Blue - Micro
    F105 - ICS/HVAC
    10 Amp Red - Micro
    F106 - ESC-PUMP MTR
    F107 - TRLR TOW STOP/TURN LT — If Equipped
    F108 - HD ACCY #4 — If Equipped
    15 Amp Blue - Micro
    F109 - TRLR TOW STOP/TURN RT — If Equipped
    F110 - POWER INVERTER
    F111 - TRLR TOW BACKUP — If Equipped
    * Customer can select to switch the Cargo Power Outlet from F43 battery fed power to this position F45 which is fed when the ignition in ON.
Similar Threads
  1. Torque specs on grade 8 bolts
    By Mike_JK_Houston_711 in forum Jeep JK Wrangler
    Last Post: 02-05-2017, 06:40 PM
  2. Jk torque specs
    By LarryG in forum Jeep JK Wrangler
    Last Post: 10-13-2016, 02:05 PM
  3. Oil pan bolt torque specs
    By webejeepin in forum Jeep JK Wrangler
    Last Post: 01-10-2016, 09:45 PM
  4. Torque specs on these two bolts ..
    By Dopey84 in forum Jeep JK Wrangler
    Last Post: 12-08-2015, 07:22 PM
  5. Torque specs
    By JeepinLife in forum Jeep JK Wrangler
    Last Post: 10-02-2013, 02:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
