Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Rear Trac Bar
  1. #21
    Fresh Catch
    Join Date
    May 2018
    Location
    arizona
    Posts
    12
    I hope you don't take this the wrong way but perhaps you can't see it because you lack experience. Based on what I've been reading, you don't even seem too interested in obtaining it. I help pit for Mel on a regular basis and I can assure you that we're NOT changing out track bars "regularly".
    So in 3 yrs I have bent 2 Trac bars. Am I inexperienced? Not a professional by no means. I have been wheeling for about 15 yrs. So I do have experiance. I have bent in by being twisted crawling and prerunning it. So both worlds. It isn't that I am not interested in obtaining help or ideas.
  2. #22
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    56,496
    Quote Originally Posted by JPH8R View Post
    Fair enough, I don't know you from Adam, have no clue as to how much time and miles have actually been spent on the trail during those 15 years let alone the 3 that have caused the 2 track bars to bend and that's why I made sure to say, "perhaps". Being that you're apparently aware of what caused them to bend, may I suggest that you use that knowledge and attempt not to do the same thing again.
  3. #23
    Fresh Catch
    Join Date
    May 2018
    Location
    arizona
    Posts
    12
    I am sort of aware of what creates the bending, it tends to be at speed with hard turns. Like unloading and reloading the suspension in a turn. I am definately going to be paying more attention to the track bar after every outing. To see what may be doing it exactly.
  4. #24
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    4,600
    Rear Trac Bar
    An inherent feature of track bars is that the axle moves side to side as the suspension flexes. Because the track bar is often not parallel to the ground, up travel transfers longitudinal force to the track bar, which might cause it to bend. Up travel during a right turn will transfer even more longitudinal force on the rear bar, because turning will tend to push the rear axle to the right relative to the vehicle, which the track bar will resist. I would suspect that your bend, assuming it was the rear bar, occurred during a high speed, bumpy right turn.
  5. #25
    Old Timer DWiggles's Avatar
    Join Date
    Jul 2014
    Location
    Texas
    Posts
    3,719
    Quote Originally Posted by fiend View Post
    ^ This is pretty much my assumption as well. Even all the way from Tejas
  6. #26
    Hooked Vinnielax's Avatar
    Join Date
    Jan 2017
    Location
    CA
    Posts
    187
    Stop with all of this “logic” and “deductive reasoning “
  7. #27
    Join Date
    May 2017
    Location
    SoCal
    Posts
    4,600
    Quote Originally Posted by Vinnielax View Post
    Yeah sorry.
    Alternative: shit breaks when you go fast.
  8. #28
    Hooked rubiconrunner's Avatar
    Join Date
    Aug 2016
    Location
    lake worth fl
    Posts
    182
    I too bent a trac bar once.. I replaced it, laid off the skinny when necessary and pulled a line when necessary vs being a macho metal masher.... haven’t bent a trac bar since. Don’t know what would make 2 of them go out in 3 years though IMG_0366.JPG
Similar Threads
  1. Rear Prorock 60 raised trac bar bracket
    By OscarMike2.0 in forum Jeep JK Wrangler
    Last Post: 07-10-2015, 04:44 PM
  2. What Rear trac bar bracket is this?
    By JRied in forum Jeep JK Wrangler
    Last Post: 03-08-2015, 10:29 PM
  3. Rear trac bar and PSC diff cover
    By Stegertime in forum Jeep JK Wrangler
    Last Post: 10-24-2014, 10:25 PM
  4. Tru Trac w/ at least 3.73 R&p f&r d30/44
    By cwmt3 in forum Wanted
    Last Post: 08-31-2014, 05:15 PM
  5. Trac-Loc
    By 07streetbobrider in forum Jeep JK Wrangler
    Last Post: 12-06-2013, 03:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
