Page 1 of 4 123 ... LastLast
Results 1 to 10 of 61
Thread: Please help me - what's causing my drive shaft to make this noise shifting out of 4lo
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Fresh Catch
    Mar 2018
    Colorado
    48
    Question Please help me - what's causing my drive shaft to make this noise shifting out of 4lo
    I have a 2017 automatic JKUR which has had a CV drive shaft for about 3000 miles. Just recently I've been getting this ringing noise when I shift from 4lo back to 4hi. The sound is almost certainly coming from the drive shaft because:
    1. Tapping the drive shaft's body with a wrench yields the exact same sound.
    2. I removed the drive shaft from the t-case and the noise doesn't happen when it's disconnected.
    Here's a short video shifting from 4hi to 4lo demonstrating the issue:
    https://streamable.com/s/uu6ro/lsdktp
    For what it's worth, it also happens occasionally when shifting from Park to Reverse or from Drive to Reverse.
    I can't tell if it's a problem with the T-Case, the drive shaft, or something else in the drive line. I really need some good advice or ideas on this one. Thanks a million for the help!!
  2. #2
    Nothing but a Thing
    Jul 2016
    Canada
    1,296
    Quote Originally Posted by tylerbrinks View Post
    ]I removed the drive shaft from the t-case and the noise doesn't happen when it's disconnected.
    I can't watch the video at the moment, but this alone makes me think it's a u-joint on the driveshaft that has play.
  3. #3
    Fresh Catch
    Mar 2018
    Colorado
    48
    Quote Originally Posted by JKDream View Post
    If it helps, the joints are the Spicer Life type that don't require grease. They have about 3K miles on them, but that doesn't mean one of them hasn't kicked the can already.
  4. #4
    Old Timer DWiggles's Avatar
    Jul 2014
    Texas
    3,715
    No, that's definately not a u-joint. Watch the video. Idk. Nothing to add but I think is has something to do with the transfer case. Yikes, that doesn't seem normal at all!
    sent from SPACE!
    DZZ Build thread
  5. #5
    Fresh Catch
    Mar 2018
    Colorado
    48
    Quote Originally Posted by DWiggles View Post
    What's strange is that the sound resonates in the shaft. I can tap it with a screw driver and it sounds the same. That suggests something has to be impacting the shaft, right? The only moving parts outside of the t-case are u-joints. So, what about something internal to the t-case sending an impact down the drive line? Like the shift fork being out of whack? I wonder if an impact happening inside the t-case would send a shock into yoke and, since there's no play at all in the yoke or joints, causes the shaft to compress front to back..??
  6. #6
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    29,146
    Hold the tcase end of the shaft tight with your hand on the tcase side of the ujoint and hit the shaft again. See if noise is still there. If it is, keep moving your hand down the shaft (no homo) and see if noise eventually goes away. Look at the weight on the driveshaft and make sure both welds are in tact. If one weld is cracked, that may be the issue, just enough to cause resonating noise.
  7. #7
    Fresh Catch
    Mar 2018
    Colorado
    48
    I just crawled under my jeep and did precisely what you outlined. First, grabbing it about 14 inches from the yoke totally muffles any noise whatsoever. I tried see if one of the weight's welds were broken, but there's no weight on it. I had to do a triple check on that because I don't remember if it had one when it was fabricated. It seems smooth from the CV to the stub, no signs of the weight having broken off that I could feel. The front shaft has the weight welded to the pinion side, so naturally I triple checked the pinion side on the rear. No weight there either. It would be shocking for a shaft to be so balanced that it needed no weight, but maybe that's the case. Sure makes me feel like I need to go show the guy who fabricated the shaft since he's local and it's under warranty...
  8. #8
    Fresh Catch
    Mar 2018
    Colorado
    48
    I actually took the t-case side of the rear drive shaft off to inspect everything. I even had the drive shaft's fabricator take a look at it (while bolted on) this morning. Everyone agreed that the t-case seems like the issue, not the drive shaft. The noise is clearly coming from the drive shaft as you can see in the short clip (linked below) when the CV housing come into contact with the recess of the drive shaft's ears. But the u-joints are tight enough and have full range of motion. I still don't think it's the drive shaft that's causing the issue, but that it's simply highlighting an underlying problem.
    https://streamable.com/n4o73
    The other interesting fact is that when the parking pawl engages when I park on an incline, the same noise happens when I go from park to reverse, even in 2hi. It's like something in the t-case is building up torque and releasing it through the drive line and causing the noise.
    Finally, t-case is so darn hard to get back into 4hi from 4lo regardless of whether the Jeep is slowly rolling or at a stand still, and that wasn't the case when it rolled off the dealer's lot a year ago. It's also a bit tricky to get it to stay in 4lo - it likes to pop back to neutral unless you give the shifter a bit of encouragement. All that seems to point to a problem buried in the t-case, which is beyond my mechanical aptitude. The good news is it's under warranty, so I'm having the dealer's service department look at it next week.
  9. #9
    Nothing but a Thing
    Jul 2016
    Canada
    1,296
    sent from SPACE!
    DZZ Build thread
    Just watched the video finally. Bit confused honestly. I accidentally had my transfer case in neutral awhile ago while working on the truck, and threw it into drive and grinded some gears. Ever since it's made a similar noise going from park to reverse or drive, but only when the vehicle has sat for awhile. Unfortunately I've never figured it out. Reasoning behind the u-joint though was - I had a cap work its way loose on one of them, and every time I threw it into drive it would turn the driveshaft just enough for the u-joint to contact the ears on the yoke and make a pinging noise. But that doesn't seem like the case here.
  10. #10
    Addict JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    8,177
    Is the trans in drive or neutral in this video? Can’t say I’ve ever seen this before
Similar Threads
  1. Replies: 33
    Last Post: 07-14-2018, 04:14 PM
  2. Drive shaft help!
    By Dopey84 in forum Jeep JK Wrangler
    Last Post: 05-01-2017, 05:20 AM
  3. Drive shaft
    By Bmans08jk in forum Jeep JK Wrangler
    Last Post: 03-17-2017, 10:30 PM
  4. Strange noise from transfer case/drive shaft area
    By mattfl in forum Jeep JK Wrangler
    Last Post: 05-31-2015, 07:33 PM
Tags for this Thread
