Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Replacing Passanger HUB every 6 months
  1. #1
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,981
    Need some ideas on what might be causing my passenger side HUB to wear out so fast.
    I've now replaced it 4 times at about 6 month intervals.
    My dash ABS, EPS lit up on my way back from New Mexico @80-85mph- thought it might be clock-spring since cruise control stopped working.
    Once I got home I was back on freeway again the following day @65-70mph
    I felt a slight wobble on my way home and when I made the turn onto my street I heard the scraping sound.
    Jacked it up and the passenger side was so loose it took no effort to move the wheel with one hand...like a very loose tooth
    Axle is PR44, I don't think it's bent. I think I would have other issues if it were?
    Dynatrac ProSteer ball joints.
    Rancho knuckles.
    Luckily the hubs have been replaced under warranty but it's too suspicious that it's only the passenger side and at about every 6 months.
    I feel incredibly lucky that I didn't loose that wheel considering the speeds I was traveling at.
  2. #2
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    33,694
    I am in a similar situation. I just put in timkins so we will see.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  3. #3
    Addict JKbrick's Avatar
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    9,717
    You may have to go with a spindle with tapered bearings and lock out hubs possibly
  4. #4
    Living the WAYALIFE Ddays's Avatar
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    11,921
    Quote Originally Posted by JKbrick View Post
    I seriously am toying with this idea. Mostly based on a longevity standpoint of not having all of the front end components spinning constantly. Pretty expen$ive tho...
    https://wayalife.com/showthread.php/...build-of-Gruff
    Gruff 2014 JKU Moneypit
    Badger 2019 JLUR waiting for scraps
  5. #5
    Living the WAYALIFE wjtstudios's Avatar
    Join Date
    Nov 2016
    Location
    Rochester, MI.
    Posts
    10,422
    You’re referring to the spyntec hubs? Pricey but they look well built. It would be interesting to hear from someone with experience with them.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  6. #6
    Nothing but a Thing Speedy_RCW's Avatar
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    2,134
    You also have to go to 5x5.5 pattern and get your rotors machined to accept the change.
  7. #7
    Join Date
    Nov 2016
    Location
    Rochester, MI.
    Posts
    10,422
    Quote Originally Posted by Speedy_RCW View Post
    Correct, new wheels, brakes, 5 on 5.5 rear shafts. It’s a Pandora’s box. Thats probably why we haven’t seen anyone post up with them yet. But it’s interesting
  8. #8
    Nothing but a Thing Benito's Avatar
    Join Date
    May 2013
    Location
    New Mexico/Texas
    Posts
    1,293
    Quote Originally Posted by jeeeep View Post
    Rancho knuckles.
    I was running into the exact same issue until the unit bearing finally failed on me with almost no sign, a combination of bad roads and having hydro assist. I was traveling and was pulling off the highway to get gas. My brakes went to the floor but I was able to build pressure again to stop. the unit bearing was screeching and whining as I was slowing down, i was able to make it to an autozone and they had one in stock, I also had to replace the brake pads. I was replacing them with timken unit bearings, the one that failed was a timken.
    I just don’t think the unit bearings can handle the 37s. I was also running a PR44/ProSteers/highsteer knuckles.
  9. #9
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    11,921
    Quote Originally Posted by wjtstudios View Post
    Aaaaand there-in lies the biggest rub. It's a shitload of parts to replace to gain some longevity. I don't know that it'd be worth it in the long run. Rear shafts shouldn't be an issue but I'd have to re-drill the rotors to the 5x5.5 (Dynatrac already said that's no problem) new wheels would be the biggest deal. Christ if I bought another set of wheels I'd probably get skinned.
  10. #10
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    11,921
    Quote Originally Posted by Benito View Post
    I started changing mine yearly now because of this potential.
Similar Threads
  1. Need a new battery at 18 months old?
    By cartertripp in forum Jeep JK Wrangler
    Last Post: 11-06-2016, 10:51 PM
  2. Replies: 13
    Last Post: 05-17-2014, 03:08 AM
  3. Replies: 13
    Last Post: 01-02-2014, 03:47 AM
  4. Two months or so...
    By dahoover5866 in forum General Jeep Stuff
    Last Post: 05-14-2013, 01:45 AM
  5. Finally after 11 months
    By kludwig13 in forum Jeep Show & Tell
    Last Post: 11-22-2012, 09:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
