Page 8 of 8 FirstFirst ... 678
Results 71 to 73 of 73
Thread: WRITE-UP : WAYALIFE ACM - Jeep JL Wrangler Under the Hood ARB Air Compressor Mount
  1. #71
    Fresh Catch
    Jun 2019
    Cheyenne WY
    3
    Wiring
    IF I am only using the ARB as a compressor, what does the wiring hookup look like? I take it I don't need to hook to two AUX switches? You never explained the AUX 2 connection usage.
    Thanks
  2. #72
    Fresh Catch
    Jun 2019
    Cheyenne WY
    3
    wirng
    Quote Originally Posted by ImpactDoc View Post
    Three tips: 1)The main wire harness actually doubles back on itself to the battery, the thin black wire, Eddie looks to have crimped together with the main black and white wire. I put them on separate crimp connectors.
    2) Make sure the mount is a good 2cm or so away from the frame (Eddie gave me that tip) as rough driving will flex the frame and body slightly.
    3) Also if you are relatively slender or have long arms you can leave the fender and wheel on which I did. You just need to remove the inner fender liner.
    All in all if I didn’t have my kids interrupting me during the wiring portion it takes a total of 1.5 hrs for an amateur to install, if you have all tools parts needed. You will need a crimper or vise grips (to crimp the electrical connectors) at least and electrical tape and Teflon tape. The crimper I bought was garbage and mangled a few connectors which made me to go Home Depot to get more and I just used vise grips to crimp.
    Can you show a diagram on how you wired please?
  3. #73
    Fresh Catch
    Jun 2019
    Cheyenne WY
    3
    Relay and wiring
    Since I am only using this as a compressor, where does the relay mount and what wires are used to connect to the AUX?
    Thanks
Similar Threads
  1. Replies: 205
    Last Post: 12-08-2017, 02:51 AM
  2. MORE Under the hood compressor mount
    By mastrcruse in forum FOR SALE (Active Members ONLY)
    Last Post: 08-27-2016, 03:34 AM
  3. ARB under the hood compressor mount.
    By rctrav in forum Jeep JK Wrangler
    Last Post: 07-07-2016, 11:32 PM
