Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Lift Straight Talk
  1. #11
    Hooked dustinfromohio's Avatar
    Jan 2019
    Wooster, Ohio
    112
    I have a 2002 TJ X just like you OP, 3 inch zone suspension lift and transfer case drop installed by previous owner, zero vibrations or issues other than a somewhat bumpy ride.
  2. #12
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    2,107
    I didn’t read your whole book but a budget lift and shocks don’t need anything. No tcase drop no trackbars no sye. If you’re having issues adjust your front caster cam bolts and align toe in a bit. I ran a 4” rough country lift without a sye with no vibrations. If you’re getting rotational vibes inspect your u joints for stiffness and tire balance.
  3. #13
    Knows a Thing or Two trailraider's Avatar
    Jan 2015
    calgary
    829
    myself personally , I like the Skyjacker budget kits for the TJ's . has control arms, springs, shocks, relocation bracket and the t-case drop.... all for probably less then the paid for the teraflex kit. but I do always add a front adjustable track bar on top of this kit.
    Jeep- Adult version of lego
  4. #14
    Oct 2011
    Carson City, NV
    54,832
    What you really NEED is to install an SYE and adjustable rear upper control arms to set your pinion angle. Here's a write-up I did for this years ago:
    http://4x4xplor.com/SYE-CV.html
    While you can get by with a t-case drop, I would NOT recommend it. Depending on how much lift you actually got (TeraFlex coils tend to yield WAY MORE than is advertised), the drop may not be enough to mitigate driveline vibes. You could install a 1" motor mount lift to help but really, why pay so much money to lift your Jeep only to drop the one point you're trying to raise up right back to where you started from. Personally, the whole idea of a t-case drop is stupid. But then, that's just me.
  5. #15
    Old Timer longarmwj's Avatar
    Feb 2015
    Cumming, Ga
    3,801
    My exact thoughts. It's like those stupid control arm drop brackets you can buy. It's like you're lifting your Jeep only to un-lift it at the same time
    Captain Imachurity
    2003 WJ Build Thread
    2017 Gobi JKU Build Thread
    2016 Renegade Sport Build Thread
    2019 Compass Sport Build Thread
  6. #16
    Fresh Catch
    Sep 2018
    Colorado
    5
    Thanks very much for your suggestion, and your web site, and your videos. Much appreciated.
  7. #17
    Fresh Catch
    Sep 2018
    Colorado
    5
    Update
    Here's an update with details so that other newbies may learn. This is the lift I bought: https://www.extremeterrain.com/teraf...j-1141200.html
    The lift ended up being 2.75 inches after two weeks of settling in my case. I don't mind the extra 3/4 inch. The kit is sold as "everything you need" and that's not true. You can't get the axle alignment set properly unless you also buy adjustable track bars front and rear. Teraflex instructions tell you to drill a hole in your front axle bracket to reposition the OEM front track bar. This is a bad idea. In my case it would have resulted in an oblong hole widening the original hole and making a weak/dangerous mount point for the bar. The bracket they provide for the rear track bar does not allow for proper positioning and will result in misaligned axles. The rear bolt on bracket they provide also results in a much weaker attachment compared to the OEM welded bracket. Additionally, to get it right you have to buy adjustable rear upper control arms so that you can get the rear driveshaft pinion angle right. Teraflex instructions imply that the angle of the bolt on bracket they provide is sufficient to do what adjustable control arms will do. It is not. It puts all the stress on the wonky bracket they provide, off to one side of the axle while simultaneously being flimsy and weak. It creates a failure point that is weaker than stock and will miss-align the axle, while you are trying to raise and strengthen your Jeep. The instructions were also missing major steps like the fact that you have to disconnect the front anti sway bar links in order to have room to replace the springs. The lift also created a dangerous drive line vibration that requires a SYE and longer/better driveshaft to resolve. If you get this kit plan to buy the other parts I mention here and do it right so that you don't wind up with a death wobble machine. I have not driven it enough yet to comment on the springs but they appear to be slightly heavier duty than stock and the protective coating appears to be solid and thick.
    As mentioned in the tread above, I would also/now stay away from Teraflex, and I did not find "Extreme Terrain" helpful. Your best help and guidance is going to be a few people on this form and others who have done all this before. Thanks to all who have provided meaningful comments.
  8. #18
    Old Timer Clutch's Avatar
    Dec 2015
    STL metro
    2,990
    Let’s see some pictures! Glad you got everything worked out.
Similar Threads
  1. Let’s talk JL Lift kits.
    By Sylermack in forum Jeep JL Wrangler
    Last Post: 03-07-2018, 01:16 PM
  2. Jeep Does Not Drive Straight
    By tonytony9 in forum Jeep JK Wrangler
    Last Post: 05-13-2015, 08:52 PM
  3. So let me get this straight...?? (2012's and re gearing)
    By Sola_Christos in forum General Jeep Stuff
    Last Post: 06-16-2013, 08:04 PM
  4. Straight from horses mouth
    By 13JKUR in forum General Jeep Stuff
    Last Post: 03-01-2013, 01:35 AM
Tags for this Thread
