Page 66 of 67 FirstFirst ... 165664656667 LastLast
Results 651 to 660 of 664
Thread: Build of Gorilla JKU
  1. #651
    Nothing but a Thing RockinAZJK's Avatar
    May 2016
    Central Texas
    1,561
    Quote Originally Posted by MericaMade View Post
    Ok so I see PSC sells a bolt kit when you use the Synergy track bar brace with the big bore. But, what I can't find is do you replace the front left bolts only and reuse the factory bolts on the right?Attachment 357817
    You should be correct. When I installed my big bore in November it came with 2 new bolts for the one side.
  2. #652
    Old Timer MericaMade's Avatar
    Nov 2017
    SoCaL
    2,600
    Quote Originally Posted by RockinAZJK View Post
    Yeah it did and specifically said to replace the front two bolts per PSC but apparently once you add the track bar brace you need to get longer bolts.
    https://www.pscmotorsports.com/psc-hwk-688-pp.html
  3. #653
    Nov 2017
    SoCaL
    2,600
    I don't know how but I keep clipping my brake lines in the rear so Im moving them inboard. There was a hole that I just widen out in the shock perch and thinking of running it right through the perch. Does anybody see a problem with this?20210116_084945.jpg20210116_085014.jpeg
  4. #654
    Nov 2017
    SoCaL
    2,600
  5. #655
    Been Around the Block J&k_overland's Avatar
    Feb 2020
    Over there
    415
    Will it rub the coils? That’d be my concern
    Bertha 03 WJ
    IZZE 01 TJ
    Popeye DD-743 67 CJ5w
  6. #656
    Nov 2017
    SoCaL
    2,600
    I don't think it will.
  7. #657
    Nov 2017
    SoCaL
    2,600
    So I'm at a stand still with the Jeep after today. I just finished up rerouting the rear hard lines and set the arms to the suggest evo lengths and installed those along with front and rear Synergy tracks bars and draglink.
    KMCs order weeks ago and still 3 weeks out. Thank god I check because they had 5on5 in my order even though I ordered 8x6.5. While on the phone I switch my order over to the KMC 235 and saved a few bucks and still got the same ship date.
    Rockhard cage ordered 12/24 still waiting on shipping. This is aggravating.
    Axles seem to be on track and won't have till early February.
    Jeeps been on jack's since Xmas and hopefully I will have it rolling by mid Feb.
  8. #658
    Meme King WJCO's Avatar
    Sep 2015
    The Matrix
    32,562
    I ordered sliders from them a few months ago and it took about 4 weeks to get them.
    "A Republic, if you can keep it." -Benjamin Franklin
  9. #659
    Living the WAYALIFE JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    10,381
    That is exactly how I ran my rear lines, got these 90 fittings
  10. #660
    Nov 2017
    SoCaL
    2,600
    Quote Originally Posted by JKbrick View Post
    Sweet. I couldn't remember who did that, thanks for the pictures. I ran a new line on driver side because I broke it twice. I was able to bend the passenger line to work the same way.
Similar Threads
  1. Boz's build thread (slow build-up that is)
    By Tigereye10 in forum Member Jeep Builds
    Last Post: 11-10-2020, 04:23 AM
  2. Gorilla's super slow Building of SilverBack
    By SilverBack in forum Member Jeep Builds
    Last Post: 04-05-2020, 04:24 AM
  3. Jeep introduces Gorilla glass
    By pop2tu in forum Jeep JK Wrangler
    Last Post: 05-24-2019, 07:27 PM
  4. Gorilla Spline Lugnuts, safe with OEM wheels?
    By BenoA in forum Jeep JK Wrangler
    Last Post: 08-16-2014, 04:08 PM
  5. Currently 2010 rubicon build or buy 2013 to build
    By Charles in forum Jeep JK Wrangler
    Last Post: 10-06-2013, 05:42 PM
