Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: JK STEERING HAS ME WANDERING.... I mean wondering
  1. #11
    Fresh Catch
    Oct 2019
    Illinois
    5
    Quote Originally Posted by wjtstudios View Post
    PSC big bore XD llr. When my OEM gear went, I had a lot of play at the steering wheel and that does not sound like what you are dealing with.
    For the unit bearings, they wonít always make noise. You need to check for play in the wheel itself. Grab top and bottom of the tire and twist to see if there is any play in the unit bearing.
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    My steering wheel had the play issue for what it's worth so the new gear box fixed me
  2. #12
    Addict wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    7,698
    Quote Originally Posted by Dpindustries View Post
    Great! Check out PSC for the Gear.
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  3. #13
    Nothing but a Thing RockinAZJK's Avatar
    May 2016
    Waco, Texas
    1,314
    As mentioned Iíd look into PSC for the box and pump. It would also bug me to only have half the balljoints replaced too, so itís not a bad idea to do the other side.
    I really recommend taking off that steering stabilizer and taking it for a spin before you do the box and pump. The charged bilstein stabilizers like to push outward and couldnít potentially give you that feeling if the steering box is trying to fight it and return to center. If nothing else itís a free idea to try before you drop some coin to replace more parts.
  4. #14
    Fresh Catch
    Aug 2019
    Arizona
    19
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    I checked for play y grabbing the top and bottom of the tire by hand and don't notice any. Is this something I should be checking with a pry bar, or is by hand going to detect it?
    Sounds like PSC is the preferred gear box to look into.
    So my plan is (in this order):
    First I will unhook the steering stabilizer... it's a easy enough check.
    Second I'm also going to replace the passenger side ball joints just because of my OCD
    Then I'm replacing the gear box. Will need to compare cost to decide if I should just get the PSC and be done with it, or get away as cheap as possible since at this point I'm not even sure it's the gear box.
    Meanwhile I'm still unpacking boxes after moving into my new place last weekend... so this might take a couple weeks, but I'll report back with findings.
  5. #15
    Nov 2016
    Rochester, MI.
    7,698
    Quote Originally Posted by ken31756 View Post
    Iíve had mine torn up enough to feel movement as I twisted the tire in and out. But, Iíve also see guys have to use a gauge to show the movement because it was so small.
    As for the gear goes, with 37s and bigger the gear and pump are the minimum. I ran the PSC big bore for years and it does help when you are bound up on rocks. This spring I added the ram to the system and itís night and day on the rocks as compared to just the big bore. So if you order one from PSC, get it ported. Itís ready for you when you get to the point of installing a ram assist.
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
  6. #16
    Fresh Catch
    Aug 2019
    Arizona
    19
    PROBLEM SOLVED.... sort of
    So to finish this thread, I solved the problem.... albeit a VERY expensive way!!!
    First I removed the steering stab just to see if it was masking a problem, or maybe contributing to it (although I dont see how)
    and found it made no difference.
    Next I replaced the passenger side ball joints with Synergys to match the recently placed drivers side. Made no difference.
    Then came a PSC Big Bore XD gear box. Nice quality, big unit....but fit right in. Wheels turn nice and smooth.... however made no difference with the steering this way/ that way problem.
    I also adjusted the tow myself, moving it a little it in and out just trying different settings to see what it did.
    I noticed if I moved it enough I could feel the difference in how it steered, but it didn't effect the original complaint.
    It's like I'm barking up the wrong tree. Nothing I have done has effected the constant steering back and forth issue even a little bit.
    Then I solved the problem with the help of my brother when he came into town for the Thanksgiving holiday.
    We went out Jeep shopping!
    I test drove my first JL ........ AND FELL IN LOVE WITH HOW IT RIDES AND HANDLES.
    A bunch of paperwork later, and I drove home my new Jeep!!!
    I LOVE IT!!!!!!!!!!
    PROBLEM SOLVED!!!!!
    Attached Images Attached Images
  7. #17
    Knows a Thing or Two -AINOKEA-'s Avatar
    Oct 2011
    Hilo, HI
    924
    I LOVE IT!!!!!!!!!!
    PROBLEM SOLVED!!!!!
    Well thatís one way to do it. Congrats!
  8. #18
    Been Around the Block Primo82's Avatar
    Dec 2018
    IN
    483
    I LOVE IT!!!!!!!!!!
    PROBLEM SOLVED!!!!!
    Ha! Gave me a chuckle, thanks needed it. Looks nice!
  9. #19
    Old Timer Clutch's Avatar
    Dec 2015
    STL metro
    2,988
    Multiple ways to skin a cat!
  10. #20
    Old Timer Jsouder53's Avatar
    Aug 2017
    Gallatin Gateway, Montana
    4,202
    Congrats! Thatís one way to get into a new Jeep
Similar Threads
  1. no more hiway wondering
    By woof359 in forum Jeep JK Wrangler
    Last Post: 02-17-2017, 03:45 AM
  2. Road wondering
    By mauijim in forum Jeep JK Wrangler
    Last Post: 12-28-2016, 08:14 PM
  3. Replies: 49
    Last Post: 07-20-2015, 10:42 PM
  4. Wondering whose JKU this is
    By Jackal01 in forum Jeep Show & Tell
    Last Post: 05-26-2014, 03:03 AM
  5. just wandering
    By bumblebee in forum Jeep JK Wrangler
    Last Post: 02-21-2012, 01:25 AM
Tags for this Thread
