Results 1 to 9 of 9
Thread: 02 TJ Steering has a click/hang
  1. #1
    Nothing but a Thing Trail Bud's Avatar
    Jan 2012
    Carson City, Nevada
    1,072
    Just replaced intermediate and upper steering shafts, tie rods due to wear, and steering issue.
    I had and still have a click that can hang the steering lightly in a sweeping turns left and right. Itís at 11-1 on the wheel. It can scare you.
    I think itís by the steering wheel but not sure. I took it to my shop in frustration, they replaced a small part( washer?) behind the wheel but itís the same.
    Any ideas?
    2007 White JK Rubicon Unlimited
    EVO Long Arm
    EVO Front Coilover System
    Rear EVO Lever System
    w/14" King Coilover Shocks
    Tires: 40x15.5x20 Toyo Open Country MT's,
    20" Spyderlock Beadlock Wheels
    PSC Ram Steering Assist
    Dynatrac Pro Rock 60 Front Axle w/Competition Shafts & CTM U-Joints
    Dynatrac Pro Rock 60 Rear Axle
    Atlas 4 Speed Transfer Case
    Rock Hard Roll Cage
    Warn Dual Force Winch
    EVO Front bumper 1/4lb w/ Stringer
    Lo D Rear Bumper
    My Pictures: http://trailbud.smugmug.com/
  2. #2
    Oct 2011
    Carson City, NV
    54,019
    Since you replaced the tie-rod, check to see if your steering stabilizer is catching on anything when making a turn.
  3. #3
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    1,778
    Do you have any aftermarket accessories under the dash? Remote start, stereo amp, etc. that could be rubbing up against it?
    Still on the stock steering gear?
    Is the click kind of plastic sounding? Could be clockspring binding
  4. #4
    Jan 2012
    Carson City, Nevada
    1,072
    Quote Originally Posted by Snboarder113 View Post
    Nothing to rub under the dash.
    Yes stock gear box
    Yes click is plastic sounding/ binding.
    Good idea, thank you.
    EVO Long Arm
    Rock Hard Roll Cage
    Lo D Rear Bumper
  5. #5
    Jan 2012
    Carson City, Nevada
    1,072
    It was doing it before the tie rod replacement but I will.
    EVO Long Arm
    Rock Hard Roll Cage
    Lo D Rear Bumper
  6. #6
    Oct 2015
    michigan
    1,778
    Quote Originally Posted by Trail Bud View Post
    Yes stock gear box
    No prob, easy to test, takes about 10 minutes to pop off the airbag and take it out. Make sure the wheels are straight and tape the center piece when you take it out so it doesnít accidentally get off center. Made that mistake once. Then you can take it for a drive and see.
  7. #7
    Jan 2012
    Carson City, Nevada
    1,072
    Thanks
    EVO Long Arm
    Rock Hard Roll Cage
    Lo D Rear Bumper
  8. #8
    Jan 2012
    Carson City, Nevada
    1,072
    Follow up to steering issue.
    It was the steering box. First replaced the intermediate and upper steering shafts and clicking and hang up was still there.
    I felt like it was in the steering wheel. Anyway problem solved and the steering feels like new.
    EVO Long Arm
    Rock Hard Roll Cage
    Lo D Rear Bumper
  9. #9
    Oct 2011
    Carson City, NV
    54,019
    Worn out gear? Glad you were able to get it fixed and thanks for posting up what the problem was.
Similar Threads
  1. The axles on my Jeep go "click click click"
    By Ddays in forum General Off-Road Tech
    Last Post: 09-22-2017, 02:38 PM
  2. Replies: 43
    Last Post: 06-29-2017, 01:48 AM
  3. Bagged and mounted my first! Where to hang it?
    By catahoula in forum The 8th Slot
    Last Post: 03-30-2015, 10:51 AM
  4. Hang Over - What's your score?
    By Rccrwlr in forum The 8th Slot
    Last Post: 01-04-2015, 02:37 PM
  5. Time to Hang Up the Hardtop
    By wayoflife in forum Jeep Show & Tell
    Last Post: 04-25-2012, 04:33 AM
