Does anyone know where its at? It's not behind the dash or under the hood. Does it even have one? 97 tj
To succeed in life, you need two things: ignorance and confidence. Mark Twain
Click on the links below to improve your Jeep, your wardrobe and to help support WAYALIFE!
CB BAR | AIR COMPRESSOR MOUNT | HITCH STINGER | DECALS | SWAG | TOOLS
JT / 2020 Bright White Jeep Gladiator Rubicon
JET LI / 2018 Bright White Jeep JL Wrangler Rubicon Unlimited
MOBY DICK / 2007 Stone White JK Rubicon Unlimited
RONA / 1993 Navajo Turquoise Metallic Jeep YJ Wrangler
CALAMITY JANE / 1974 Jetset Blue Metallic Jeep CJ-5 Renegade
RUSTY / 1972 White/Blue Jeep J2000 Pick-Up Truck
EMMA / 1969 White Kaiser Jeepster Commando C101
PAPPY / 1954 Yellow Willys CJ3B
That's where i thought it would be, and all these fuses are good.
It's probably the socket mine was fried in my tj, you can double check with a test light both at the fuse and the wires at the socket
If you don't push the limits how do you find them??
I'm either out jeepin' or perparing to go out jeepin'!
Which fuse is it though? Lol I'm sure its tied in with other parts. Everything works but the cigarette lighter. I'm gonna go pull the lighter out and see if there power in the connector
Pretty sure its the radio but my lighter doesn't work either so I cant check to be positive
My radio works though.
I'm not saying the fuse is bad just as far as I can remember that's the fuse its tied in with. So like trailbear said probably the socket or maybe the wires. just start poking around with a test light it will show up.
I thought cigarette lighters didn't have fuses? I was told they were just ran straight to power![]()
On my 99 the fuse is #19 which is empty in your pic. Put a 10 amp fuse in the slot and try it.
