I am sure someone(many on here have DTD) will correct me if im wrong, but i dont believe you use them with the DTD system dut to the bypass shock performing that function.
No if you look at what Eddie said you can set the the by-pass shock to act as a bumpstop.I was wondering do you still need bump stops for the rear DTD?
ummm..correction... -> I <- was the one that said the bypass shock would do it :thankyou: ...Mr Eddie said the DTD system could be set to function in place of bumps(just to be clear that I was more clear lol) :harhar:
