13 jk axle seals
agiron
My front passenger side axle seal is leaking, would anyone in the Denver metro area be willing to help? I can get it to the point you pull the diff out, but don't feel comfortable doing any more than that.
I'd help if I was anywhere close but honestly if you have the carrier out then the rest is easy. What part after that is intimidating you?
Just curious, what size tires are you running?
If you have less than 100,000 miles your axle shaft seals are covered under the 5/100,000 drive train warranty. I have had my 14's replaced twice now under warranty and I run 35's.
Thanks for the info. Mine have even leaking on my 13 with 40k and on stock tires.
