2013 jk where to route wires through firewall?
In5ane1
Just not sure if I'm going to like the switches always having a red light on, even when key isn't in....This won't cause battery drainage will it?
There should be 3 tabs on the back of the switch. One is for 12v constant one of the the relay and the third is for the ground. The switches I have will light only in the on position.
R/
Will
In5ane1
R/
Will
These switches have wires soldered into internal circuit board. You can't get wiring wrong. They are made to be lit when even in off (Red). When you turn them on, they are green.
