View attachment 319784View attachment 319785
Worked out a deal with JCR in Kalamazoo Michigan to fully wrap my Jeep in all their parts, front and rear bumpers front inner fenders and half doors.
View attachment 319802View attachment 319803View attachment 319804View attachment 319805View attachment 319806
Wheeling with friends the next day after Kentucky down in Tennessee sandmines trail part of the twra trail system best trail I’ve been on so far in TN, then down to trail 21 and 22 at windrock
How close is that sandmine trail to windrock?
Any issue with the rear upper control arm axle mount spacing? I’m doing this right now and had to cut off the locating tabs to move the mounts in so I’d have clearance for the control arm hardware. And could you post a pic of where you drilled and tapped for the rear ARB? I have a plan for where I’ll put it but curious to see where others did as well.
View attachment 319809View attachment 319810View attachment 319811
Here are my front and rear arb line locations in the rear I drilled a 2” hole through the truss and mounted Next to the stock breather location (not used) I ended up putting a fitting in my diff cover as I was building too much pressure and it was pumping diff fluid up my arb air line into the engine bay
Very nice build. Salt sucks, what are going to use to repaint them with?
Not sure yet I have a few ideas, I like the tractor implement paint from tractor supply but for it to work well you have to mix and spray yourself the spray paint version is not the same
New update staring front coilovers and hydro assist View attachment 320550
axle set at bump for final measurements before the factory brackets came off
using artec tall towers had to cut 2” out so the factory harnesses could stay in place by the fuse box
towers are in now waiting for the coilovers to show up before I burn everything in for good I’m also installing king 2.5 bump stops for when the trails get out of hand
