jeeeep
My son's 2010 had the same issue, we took the stabilizer off to see how it would do and it would drive straight. We reinstalled it and it pulled again to the right. I was told by a 4X4 shop to extend the stabilizer all the way towards the drivers side and that should fix it? Haven't tried it yet, but hopefully today. Will let you know.
you could end up collapsing the stabilizer too much on a RH turn.
The proper way to adjust a stabilizer is to loosen the tie bar steering stabilizer mount
turn the wheel full passenger side to lock, then collapse the SS so there's at least a 1/4 amount of the SS rod left before full collapse and tight the SS mount
turn to full driver side lock and make sure the SS extends out without reaching full extension.
From that point you can fine tune it a little taking care not to over-extend or over collapse the SS
