2016 Rubicon Hard Rock
sponnythegr8
Well didn't get to work on my rig last weekend as planned got mandated to work but I made up for it this weekend. I installed a dead pedal, hood assist and some AFE exhaust.
sponnythegr8
Front lower control arms will help you get your caster set right which will help with getting your steering geometry back to stock
That's kind of what I had in mind also along with some adjustable track bars to re center the front and rear axles. I would like to increase my caster about 1 1/2° to approximately +5°.
cozdude
Guy with a Red 2-Door
Being that your at 3" of lift you would benefit from a drag link flip kit more than an adjust able track bar. Also a rear track back Bracket to raise it up will work as well. As for caster you want to stay right around 4.2* which is what you get stock
sponnythegr8
I have a rear track bar bracket on there now that came with my kit. What will the drag link flip kit do for it?
mudmobeeler
It will flip the drag link to get your steering back to normal and it raises the mount on the axle side for the track bar to get it parallel with your drag link. That in turn will help center your axle also so adjustable track bars aren't needed.
sponnythegr8
OK thanks I will check into that as the steering could stand to be a little smoother.
