toxicwaste29
Here is a short brief write up for replacing the coolant temp sensor on a 3.6:
The new 3.6 doesn't have the coolant tempo sensor near the coolant inlet on the front of the block. I had to do some searching before I finally found it. Below it can be seen circled. The first is it looking down near the steering shaft. There is absolutely no way to remove the senor from up top without maybe removing the steering shaft. Instead I decided to remove the driver inner fender liner to reach the temp sensor. This part there is only one 10mm bolt and the rest are plastic pins. After the liner is removed there is tons of room for reaching the sensor. The plastic connector on top needs removed first and then the sensor can be removed using a 19mm wrench. Now since there is coolant in the block you want the new sensor ready to go in. As soon as the old sensor is out immediately put the new sensor in and tighten it down. Some coolant will be lost but even if the radiator is drained coolant will still be in the block causing it to be lost anyways. Now the electric connector can be hooked back up and the inner fender put back into place. I let the jeep run and burp any possible air bubbles out however this step can be skipped since the engine should burp itself as it runs during normal driving.
