My 2009 JKU Rubicon engine has had various ticking/clicking noises from the vicinity of the valve covers pretty much since it was new. :crazyeyes: With a little over 117,000 miles, the engine still ticks and has a random knocking noise coming from the bottom end (oil pan) area. Diagnosis can be extremely difficult in light of the various conditions that can produce the noise. Some have mentioned cracked exhaust manifolds as the cause. It is true that a cracked exhaust manifold can make a ticking type sound but, as many have discovered, the noises continue after new manifolds have been installed.
To be more specific, I believe the noise most of us experience is due to a noisy valve train. Hydraulic lifters, rocker arm assemblies, and push rods to name a few could all contribute to the noise. For the most part, I think these noises are normal characteristics for these motors. I mean after all, at 117K miles, my 3.8 is still running. :yup: I would guess many of you experiencing a noisy engine are still wheeling despite the annoying tapping sounds emanating from under the hood.
The point I'm trying to make is this: If you seldom check the oil level and let the oil level run low or, wait an extended number of miles (past say 4000 miles) before changing the oil and filter, or neglect to replace the air filter on a regular basis, your motor is not going to last. Some folks may be mistaken that the oil pressure warning light will come on when the oil level is low. It will, but only after the oil pressure is practically zero. By then, it's almost assured your motor will be history.
Another opinion of mine I'd like to mention is about oil viscosity. In most cases using thicker oil is not going to help. In fact, it could make things worse over the long term. The two main reasons the auto industry recommends 5w20 is to speed up engine lubrication and improve fuel economy. Thicker oil will only hinder the engines ability to quickly lubricate vital components inside your motor; especially during cold starts. Stick to the recommended oil for your climate and change the oil and filter on a regular basis and you will get lots of miles out of your engine.
I hope this helps! :yup:
