Can I just run these coils and shock extensions sort of build my own lift. Upgrade along the way. I currently have the Daystar 1.75 coil spacer with the rear sway bar drop.
Adjustable control arms, track bar relocation bracket F/R, extended brake lines, drag link flip, new shocks, driveshafts. Everything that's in the enforcer kit.
If you a bit tight look at the OME 2" coils.
They'll give you about 2.5" lift and decent spring rate over spacers..
Running them alone will be fine temporarily.
Then you can start modularly adding trackbar brackets, longer swaybar links etc.
Luckily these aren't too pricy.
I think if you jump to 3" coils which will probably yield more than 3" there's no getting around the added bits to complete the setup.
