3" Lift w/ Rockstars - What is the best shock Length?
MericaMade
I’ll install and run the setup without the rockstars first... then go from there. I’m only going with 35’s right now, so I don’t want to be too high.
I am currently running 37 on 3 inch on a 17 Rubi JKU and for me the height and width with 3.5 backspacing is perfect. I ran 3 inch on 35s for a little while and was really happy with that stance as well and im sure you will be happy with the height.
Sent from my SM-G960U using Tapatalk
rubiDave
Are the rear sway bar links that come with the enforcer lift compatible with rockstars? Don't the rockstars raise the sway bar link mounting point?
JK_BUB
I am trying to figure out the best Rancho RS9000 shock length to buy for the Rear if I run Rockstars. I don't really want to add any additional bump stop than provided with the EVO enforcer 3" kit. But I also don't want to damage the shock. My other concern is that the EVO kit will level the Jeep and I may want to add a 3/4" spacer in the rear to help when the Jeep is Loaded.
Rancho RS9000 specs:
shock - compressed / extended / travel
1. 3.5" - 16.8 / 27.2 / 10.4
2. 2.5" - 16.1 / 26 / 9.9
3. 1" - 14.6 / 23 / 8.4
Is anyone running this setup that can give some advice?
I suppose if I get the recommended 2.5" shock for the 3" Lift... and if add a 3/4 spacer, I could add a 3/4 extension to the bump stop which should offset the 1.5" difference the Rockstar will make...? Or do I just ditch the Rockstars?
I have the 1 and 3 sizes of the RS9000 sitting in my garage. I see that you are in SoCal, so if you are close to Rancho Cucamonga, you are welcome to come by and try them out. I may even make you a killer deal on them (free!), if you seem like a cool Wayalifer. They are in near new condition.
TrailHunter
Really appreciate that... but I already purchased them and they are on the way. Thank you for the offer!
