jeeeep
No procal before. I bought it used with everything stock and went straight to building. As soon as the 37s were on I Procalled it. How can I lock out overdrive, when it's an automatic 2013. There's no OD button.
with the newer auto transmissions you have to use the tap-shift feature to lock out OD, it you move (tap) the shifter to the right you'll see what gear you're in on the dash, move(tap) the shifter left will shift down one gear.
I had a similar shift issue with my 2010 when I went to 37's and had made several adjustments with the programmer, try this:
First using your procal put your tune back to stock
The following steps is information I got from Quadratec and is what solved my issue, however, I only did steps 1-3 :
The following procedure will allow you to reset the memory and allow the computer to 're-learn' how to drive by adjusting to the drivers habits and the vehicles modifications.
1. Disconnect the battery by removing the positive battery cable. Remember, the positive battery cable.
2. Ground the positive cable to the negative cable for 30 seconds to erase the electric charge in the capacitors.
3. Reconnect the positive cable to the battery.
**** I did not do steps 4-7 to solve my transmission shifting issues ************
4. Turn the key to on but do not start.
5. Turn the headlights on.
6. Turn the headlights off.
7. Turn the key off.
The ECU has now been reset to its factory settings. For the next 50 warm-up periods the ECU will re-learn the engine and driving habits for your driving conditions and the newly installed parts.
Once you've reset the ECU, reinstall your Procal tune and test drive, hopefully this also helps solve your issue.
