Just installed a 50" Cree LED bar. I have the typical whistle and outside of removing it what are the best solutions you've come up with to stop the whistle. Also I'm getting an electrical interference which I never had before. I routed everything following all my current wires for my other 2 sets of LED's and my CB radio. Thank you for any help /advice.
My wire is run on the drivers side in a similar fashion but NOT tucked under the bracket. Runs next to the bracket (using wire ties) and under the cowl. No electrical noise ever.
So the thought is the interference is because my power cable runs down the passenger side by my antenna causing the radio feedback. Once I flip my light bar I hope that it's fixed. Also it'll make it easier to silicon the side fins on the bar which I started. That has cut it down but I still get it from 50-60 mph. Hopefully I can finish it Sunday.
