The attention to detail is just wild. And awesome.All filled in.
Did 3 rounds of rough sanding with a flap wheel then going back over and filling any low spots with silicone bronze
Once everything was level, hit it with the DA
Wow that’s dedication. Lotta time under the hood right there! Came out awesome. Forgive me if you already mentioned this, but are you using silicone bronze filler metal on all of this tig work?All filled in.
Thanks friend!The attention to detail is just wild. And awesome.
Thanks!!Wow that’s dedication. Lotta time under the hood right there! Came out awesome. Forgive me if you already mentioned this, but are you using silicone bronze filler metal on all of this tig work?
Thanks!!
Yes I’m using silicone bronze in the stuff I consider “non structural”, mostly sheet metal and the like. Nearly all of it is 1/16” rod but I have some .045 for the really thin stuff
Strength wise, it is very good. About 50,000 psi compared to the 70,000 of the ER70S2 I use for the high strength steel welds. Bottom line is it shouldn’t come apart AND it’s much easier sanding it
I see it’s a typical Jeep windshieldSeats are in and fully mounted now. Cut out a chunk of 3/16” plate this morning, spaced out the mounts appropriately and burned them in. LOTS of clamps and a big chunk of angle to keep things flat while welding
Both inboard seat mounts will require a small gusset on the forward edge
Bent up some chunks of 1.5” DOM and made some hip guards. They also triangulate and reinforce the rear of the cage
Added two small 1” grab handles and called it a day
Hahaha! Thanks! Yes, horribly brokenI see it’s a typical Jeep windshieldthis thing is going to be killer when finished.
Shit I don't think I'd bother with umhw for shims, just get some nylon washers at the hardware store. Pretty bad ass whoever you decide to do...Now that the seats and brackets are in, I was able to figure out the radio mounts
We wanted to get both under the passenger seat and it was a SQUEEZE. Layed out the mounting brackets…
Drilled 8 holes for welded nutserts
Burned them in
And now they’re mounted. I need some strips of 1/2” UHMW to push them off the floor but you get the idea.
They fit VERY well and are a good use of space in the fairly cramped cab
Yeah, I just want to make sure I have them spaced off the floor quite a bit. Not only for air flow and cooling but also if water and mud gets in I don't want the radios sitting in it. UHMW is great stuff, only about $25 for four feet of 1.5"x.5" thick material. It drills and machines very nicely and wont ever corrode in addition to being somewhat of an insulatorShit I don't think I'd bother with umhw for shims, just get some nylon washers at the hardware store. Pretty bad ass whoever you decide to do...
Thanks!!Great attention to detail on this build. It's coming along nice![]()
