Rock40
Clutch master and pedal retrofit. 316 stainless to make a clevis in the correct width for the pedal. I looked, not available commercially in the size I needed
![Clutch master.jpg Clutch master.jpg](https://www.wayalife.com/data/attachments/315/315983-d140528c1b3ff4dc4445024b1274a78d.jpg)
![Clutch master(2).jpg Clutch master(2).jpg](https://www.wayalife.com/data/attachments/315/315985-f4a896a2add0f5f4d6ae675b1167245c.jpg)
Pedal alignment. All three are finally hooked up here
![Clutch master(3).jpg Clutch master(3).jpg](https://www.wayalife.com/data/attachments/315/315986-caf88a9149f55c081645ba885e180e27.jpg)
UHMW spacer for the master. This helps space the master out far enough from the firewall to ensure it is getting the full "throw" from the pedal
![Clutch master(4).jpg Clutch master(4).jpg](https://www.wayalife.com/data/attachments/315/315987-b4905e4d78ae2d8e85e83e46cd53f2b9.jpg)
![Clutch master(5).jpg Clutch master(5).jpg](https://www.wayalife.com/data/attachments/315/315989-3e6989d13dad6fe29cd26b7cc58670ec.jpg)
Added a threaded rubber pad to the bottom of the pedal. That way it won't slam against the floor every time the clutch pedal is depressed
![Clutch master(6).jpg Clutch master(6).jpg](https://www.wayalife.com/data/attachments/315/315991-8ab3c66a3f6b69da90ddc2acbf015649.jpg)
![Clutch master(7).jpg Clutch master(7).jpg](https://www.wayalife.com/data/attachments/315/315992-e4cd992a7c737a83026f461926cec898.jpg)
