Thanks. I thinks so too. Starting to come to life now.
An old freind of mine was just here yesterday and said pretty much the same thing. Hahah.
Moving along nicely - gonna be a beast!
Matt seen a guy had his cut off so clean he just needed minor grinding. He said he used Diablo blades in his sawz all. I grabbed a 3 pk to see if this was gonna help. Havnt started that yet. Ill be out there today or tomorrow. I'd really like for these blades to do some magic show. Im skeptical.Now all you have is to grind, and grind, then grind, and after that grind the old welds off
Looking like it will be a beast soon!Rear axel is in and fully attached. Shock tabs burned in. CA mounts burned in.
Front end of frame is almost done getting ground down and cleaned. The diablo blade didn't really save any time. It still sucked doing all that grinding. Oh well that part is almost done too.
Over the next day or 3 the goal is getting fromt axel in with all mounts burned in. Then tear it all back down and get everything in some new paint!! Still have a few parts to order but we all know that never ends.
Rear has been moved back about 5 inches. Front is going as far forward as possible. Really hoping to hit a 113 to 115 wheel base.Looking like it will be a beast soon!
Are you stretching it a bit at the same time? Seems like now would be the perfect time for that.
