desertrunner
For those with an air compressor inside the jeep how are you Routing your air lines to your axles?
Where's your compressor mounted. And what route are you taking after the drains to avoid exhaust?Through the floor drain holes
Heat tape is a good idea…I’ve melted a hole to my rear locker just before I needed it. ..also get an air line splice kit for your tool bagBulkhead connector, mine is mounted in rear tub. Excuse all the tools laying everywhere, was working on some mods with my deck removed and the back became the catch all for tools.
Then frame rails to upper control arms. Heat tape on air line near front axle in the same areas as the heat taped wiring bundles.
Looks great! It was too late when I noticed I should’ve gone with the under seat mount instead of under the hood. It’s a tight squeeze where mine sits lol still love it though now that it’s installed and working!Went the under passenger seat route and air lines out the drain holeI think it turned out nice
