Anyone know somebody from Synergy?
In all seriousness, OP, if you have some old punches or any tapered rods, or drift pin, put them in the two holes that are closest and lightly tap them in.
You will know quickly whether it will go with just a little bit of effort or if you need to stop because it will never go.
Obviously the jeep frame is thin and you don’t want to wallow out the holes, but I have been surprised many time when holes look like they will never line up and then tap right in with a drift pin.
It also might reveal your problem area a little more. Once you start tapping it in, depending on how it shifts, you might notice that your OEM bracket is bent.
Bought the knockoff copy of the Synergy one and it lines up perfectly! So the issue IS the Synergy bracket. I am perfectly willing to deal with the occasional issue, the problem is, they have no intention of making it right. I was going to buy the rear four link but no way I am buying anything else from them. Companies that won't stand behind their products suck!
Sorry you had a bad experience with them… it is unique.
Also, hope you painted that OEM bracket with some frame paint.
Didn’t have to tell us it was a knockoff, the welds made that clear.
I thought the synergy bracket looked off from the start but had never installed one so I stayed quiet. Have you sent them a picture of the new bracket saying one of their competitors’ brackets fit perfect? I would.
I also wouldn’t necessarily call it a knockoff as there other brands that make them.
You mean there are other knockoffs? I’m shocked!
So you paid someone else for a copy of a design Synergy invented?
Sucks Synergy didn’t respond but I’m not a fan at all of rewarding copycats.
I'm not either. That's why I bought the Synergy one in the first place.
I need my Jeep back together, I am supposed to be going to Moab in a couple of weeks.
I sent them the picture yesterday and now they are all apologetic and say they are "working on a solution", whatever that means. The solution WAS to send me a bracket that was made correctly.
Bumpers can be made in a myriad of ways. That bracket? Not so much.
Back when the Rule of Law and the Constitution still mattered to people in this country, one of the major concerns about China was its blatant theft of intellectual property and rampant counterfeiting.
There are other American companies who make them. Doesn’t always have to be china.
I ran into the same issue you did even after grinding the welds, it just got to be too much. It’s now a paper weight. I wasn’t too sure if the XR frame changed. First issue with Synergy. Bought it second hand.
Went with Rusty this time not worried about the sector shaft.
If anyone needs the new bearing type let me know!
Just an FYI in case anyone comes looking in the future. I have heard that as some point jeep added extra bracing where the track bar mounts to the frame. It may have been related to JT only, but I cannot imagine it wouldn't also be added to JL.
