ARB Twin Compressor mounted in the back
JAGS
What do you use?
Still running Rubi lockers so don't need air lockers. I've got a ViAir 400P from when I first got the jeep. It's not the fastest ever with the 37s, but it does the job.
I won't be using mine for lockers so this is a non-issue for me.
Yeah, the note I made is only if using for lockers and connected with the oil. If not, than wont ever have any of those clean up issues.
H8ROADS
Here's where I mounted mine
bp9YZEE
Edit:
Can't get the link to paste right from my phone...
http://imgur.com/bp9YZEE
Did you just screw this right to the sheet metal or did you use something in between?
dyn0mitemat
I took the back plate off the compressor (8 bolts holding it on, 4 top, 4 bottom), I drilled out the nutserts so they fell off (so I just had holts in it)
I pulled the carpet back, held the bracket up where i wanted it, marked the holes, and I then drilled and put nutserts in the tub where they lined up. I put the bracket from the back of the compressor up and bolted it to the tub, and then put the compressor up to it and put the 8 bolts back in holding it to the backing plate/mount.
I then just cut the carpet around it to fit.
Works good, and keeps it out of the mud, water and heat, so I'm happy.
H8ROADS
I would have loved to have seen a writeup on this :) Thanks for the details. I'm trying to decide if I want to do this or make a bracket of sorts. If you have a chance, some close up shots of it mounted to the tub would be fantastic for reference, but no worries if it's too much of a pain!
dyn0mitemat
I can do that for ya, but I just finished shoehorning all my tools, gear and camping supplies for a trip out to rausch creek this weekend. After I get back I'll unpack and get some more photos for ya.
H8ROADS
Perfect. I'm still waiting on my tank so I won't do any mounting for at least a week. Thanks!! :beer:
