On step 8 - I ran it out the same hole but the grommet for the tail light wiring is only big enough for the light wires themselves, and the grommet won't fit back into the hole properly with the antenna cable beside it. What did you do to solve this? Bore out the grommet so both wires could run through it? Carve out a bypass hole on the edge?
