That's the nature of the automatic, it's not so smart on the hills when it comes to choosing the proper gear so use your tap shift and shift to the gear you want.
On my 2010 I lock out OD. On the 2015 I use the tap shift, similar to locking out OD but with more options :thumb:
For all that are wondering - it's a modern auto transmission, therefore computer controlled. How it shifts (at what RPM's and the likes) is based on a shift table (an information table) that the programmers at the factory decided on (which is why it shifts the same even when you regear/etc).
The shift points can be modified through certain tuners, or custom tunes. What the factory values are/what you could change to I have no idea, as I haven't moved into the world of tuning on my Jeep yet. Shift points is something I would like to play with when I do. That's just my basic understanding of it.
I have an 08 with 5.38 and 37s. Flashpaq Tow Tune with which the transmission shifts much better. It doesn't hang like the factory or 87 octane tune.
When using stock tune I would manual downshift..
The transmission also has an adaptive memory so if you drive it easy it eventually gets sluggish and lazy. The cure is to remove battery cable for 10 minutes. Or just step on it once in awhile to wake it up.
I have had a few different circumstances of this with different setups in my 13' jku.
factory 31's with 3.21 gears would hold gears on hills way to long.
35's with 3.21 gears was about the same
35's with 4.56 gears it holds gears towing up hills or on long grades under any acceleration
35's with 5.13 gears now it never holds a gear unless im towing a long hill
I think we are just terribly underpowered and dont realize what we have settled for.
That may be true, but they werent designed to be F350's, or corvettes. Lol
I mean, that doesnt stop me from driving it like it is...Wait, they weren't!? I have been SO misinformed!
I'm curious how was your fuel mileage affected with each gear set change? I'm sure as you increase numerically in gear sets, your highway went down, but did your city/highway average stay the same, increase or decrease? Just wondering as I've seen in the past not all vehicles need low rpms to get a better average fuel mileage.
Stock was 17/18 with my style of driving
big tires and stock geras was miserable and only lasted a week or two
35's and 4.56 I was averaging 15/16
35's with 5.13 i average 17/18 again
Most my driving is a pure mix 10 miles highway and 10 miles surface streets and stoplights. Daily commute one way.
I really think that going by the tire charts everyone seems to refer to they fail to take into consideration rolling mass and rolling resistance. To get back to stock-like performance you have to go deeper than the chart suggests. By the ratio calculations the chart is right but the ratio alone doesnt take into account outside factors.
This is a good point!Stock was 17/18 with my style of driving
Yeah I have an auto, being that I live on a mountain I go up an down it every day
My jeep struggles half the time. It's like it can't make up its mind which gear to put it in.
Doesn't help Pennsylvania is nothin but hills.
I need a trans oil cooler lol.
That's the exact question I was needing answered because I'm moving up to 35s / 315s and I'm wanting my power back and was wondering what gears to run. I also to slit of high way and city driving DD. And pull a lot of big hills man the 3.21 gearing sucks with even 285/75/16 tires. So would that be the ideal gearing is a 5:13 for a 35 inch. Again I do a lot how high way and high way hills. Hows it pick up on the high way? Can you get up to speed quick and stay with traffic? Also would love to see a video of you driving it to watch the rpms and mph on the high way. Man I hit up to 4,500 to 5,000 rpms up hill and am only going around 55 to 60. I don't get it my tires now aren't big. If any ones got some suggestions on what to do what love to hear the Feed back. Thanks!
