zimm
I watched some youtube and read through the dynatrac instructions. The instructions list the exact press part numbers that a guaranteed to work. No idea how much all that Miller stuff it.
It looks you need a ball joint press, the angled "jeep" adaptor, and the dynatrac recommended adaptor too.
I was thinking of this: https://www.amazon.com/dp/B0002SRGXY/_encoding=UTF8?coliid=I1YWMNCHLS8LQG&colid=2GNHQJEKR9ONY
And this: https://www.amazon.com/dp/B0002SRGW0/_encoding=UTF8?coliid=I2QNGVXLYC2588&colid=2GNHQJEKR9ONY
And the dynatrac adaptor: Dynatrac Kit JP44-1X3050-B Dynatrac strongly recommends buying the additional installation kit. It is designed to work with most off the shelf press kits. The bushing kit provides a safe area to press on the ball joint bodies preventing damage to other components.
Here's the list of press parts from dynatrac:
Ball Joint Press Kit, Or Shop Press Equipment (Miller Kit – 6289)
o C-Clamp (Miller C-4212F)
o Press Tools (Miller, 6289-1, 6289-3, 6289-4, 6289-5, 6289-12, 8975-2) o Should order Miller tool 8975-2 separate from Kit – 6289
Edit- just the c-clamp is $309! https://www.toolsource.com/ball-joint-tie-rod-tools-c-433_546/ball-joint-press-p-114268.html
This looks like the "master" kit that was referenced in an earlier post, that has the angled adapters. https://www.amazon.com/Alltrade-648...d=1499197439&sr=8-8&keywords=ball+joint+press
