Mounted my 40 inch coopers on Slabs last week. It is a pain to get the bead seated before bolting up the ring. Also the lip of the rim sticks out about 3/16" of an inch on the back of the tire which is normal. On my old Nittos it was flush because of a different design on the bead.
Man I have the same wheel and tire combo and I have to put air in mine almost every other weekend. It'll be all the way down to 7-8 psi! [emoji6] [emoji106]that's how most vendors ship beadlock/tire combos - my buddy got his the same way.
There's usually some mold form flashing on the inside of the bead, some manufacturers do a better job of trimming it than others.
if there's more than 1/8" carefully take a razor and trim it off - Don't cut into the tire bead!
trimming the flashing makes it easier to seat the bead around the wheel. if there's too much flashing and it folds up between the bead and ring, it'll slow leak.
Did you end up using the O-Ring that comes with the install kit for the wheels? Not really sure if I need it? I'm assuming these just slip in on the backside to make the rim flush against the rotor. Didn't have to use them on my pro comps.... View attachment 267908
Does that bag have any numbers on it? I'd buy them from you if you don't use them
I'm going to use them as majority of the guys on another thread that have ATX wheels suggested I should.
Just wish it was every weekend!
Haha! That was a joke. I lose air cause I air down to that when wheeling! [emoji106]Weird. I'm going on 2 months without losing a single PSI....
Got himmmmmm!!!! (Intentional talk if your a baseball fan)Ah you got me. I was going to suggest that you forgot to install the second valve stem.
