benatc1
Thanks man! should some some fun install coming up!
Let me know if you want some help drinking your beer [emoji106]
Oh, and take a look at MTG's build thread. We used the crate that the carrier came in to build a frame to help steady the carrier for installation. The frame and two floor jacks made it a lot easier.
(and let me know if you need extra hands for the install because I am always happy to help if I can)
Notice how after all the beer posts came up, Sharkey was willing to lend a hand.......
^^ :cheesy:
My momma didn't raise no fool.
Personally, I like the carrier to match the bumper. I think the corners look good both ways (matching the carrier and rest of the armor or matching the paint).
I'm not sure if you have seen pics of the corners removed after use for a few winters, but rust is definitely a possibility. I have this idea that you could "make" a perfect gasket to protect your paint and body by first spraying plasti-dip on the body. Basically, just cover the entire spot beneath the EVO corners. If you overspray a bit you can just peel the plastic-dip off. In theory, it should work fine as a protective layer between the body and EVO corner skins. It definitely adds some work to the install, but its something to consider doing after you have fitted the corners but before you get them back from powder coat/paint.
awesome, I'll definitely look into this even though we don't have road salt there is still alot that can build up in thereYes, I would still silicone the edges and holes, even with plasti-dip. You will have a pretty decent gap on the bend around the corner.
oh yea, now that I have more time, figured I'd get this thing caught up to where I want it to be!
Sent from my SM-G928V using WAYALIFE mobile app
thanks, looking fwd to getting it installed. almost to clean tho, needs to be dragged over a few rocks![emoji12]For sure. I'm glad you're schedule is letting you work on the jeep! That dynatrac diff cover is sexy.
I'll do my best!Yep! And the best part is, it is bombproof! Don't mess it up too much though
got a few things starting to roll in, want to change my diff fluids and figured I'd throw one of these on as the Red ARB cover doesn't fit colorwise with my new jeep, plus this will fit better and not have a dumb dipstick with is a pita.
Also grabbed some evo front lower adjustable control arms to get everything dialed in, being the terrorflex ones I have are beat.
should be receiving more of the armor and tire carrier early next week, Axle shafts probably next week as well.
Also started sourcing the parts for a dynomax quiet crawler and about have showed up, tail pipe is 2 weeks out.
so plenty of work ahead!
