Best grease for greasing suspension parts and drive shafts
G-mansjk
Good old Lucas marine grease is all I use for everything. Good lube, it's water resistant and helps fight rust. Only place I don't use it is on brake caliper slide pins then I like using synthetic silicon.
That's right I'm a window licker, I can't spell, my grammar sucks!!!!
Mud-Daddy
I use Green Grease on Everything, never any issues (except brake caliper slides of course!) It repels water like polar opposites.
2016 JKUR - 3.5" lift on 35's
Jsouder53
Have you guys heard of the Lube Shuttle Grease Gun? I can't believe this isn't the industry standard. Looks like NO MESS and super easy to change the cartridge.... The only problem I see right now is you have to buy their grease... but they do have a MOLY grease. I was just curious if someone has tried it.
https://www.youtube.com/watch?v=dDzftPU7iTw
Here are the greases they have:
https://lube-shuttle.us/lube-shuttle-grease-data/
Thats awesome [emoji106] thanks for sharing that product
Bear_JT
Wow, that looks worth a try. Pretty cool.
It’s cool but not $100 cool. I’ll just get a little man glitter on me when I change a tube.
TrailHunter
The gun is only $65... A locknlube gun is $85. I think most would hit their joints more often with an easier setup. Just not sold on the grease though.
OverlanderJK
Resident Smartass
What’s your concern with the grease? It won’t last?
I might grab one of these and try it. Although I’m a bad test since I never grease anything lol
TrailHunter
Lol... I guess my concern is it not being compatible with the grease in the joints now or fucking up the joints... Not sure really. I'm no grease expert. I just don't want to fuck up my Johnny joints or Dynatrac Ball Joints. But it's Grease right? What could go wrong?
QuicksilverJK
I just don’t see the 30 seconds and 2 shop towels that are saved per tube change to be enough incentive to switch. Maybe I don’t grease as often as some, but a tube lasts me a long time. Might be nice in a high usage environment where you go through a few tubes a day.
If you look at the bundles that come with both gun and a few grease it’s a hundred bucks. That’s $80 more than I’m willing to spend on grease ha. If it became more popular (not proprietary) and price lowered I’d give it a shot.
cozdude
Guy with a Red 2-Door
Seems cool but I personally don’t see the need for this. I have a gun from harbor freight that I got for $30ish. I use it everyday at work greasing suspensions on every truck I work on and it works great. Maybe use a tube every 3 weeks or so. It’s not fancy but gets the job done
Bierpower
This is kind of what I was thinking. I'm not sure if people are pulling back the plunger and trying to scoop grease back into the gun from a tub, but I just don't see a regular grease tube change to be that labor intensive.
Slimebones
And more to the point, hasn't it been proven that synthetic oil is a better lubricant than conventional oil (less friction)?. Therefore wouldn't a synthetic grease be better than conventional? Fully aware that there are a lot of different opinions on what is the best oil.
